#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
AWE Tuning
Old 07-07-2021, 03:12 AM   #1
BossMS
Drives: 2016 Chevrolet Camaro 2SS
6th Gen Camaro 2SS “Clank” Sound from rear driver side
There is this sound that I’m hearing from the rear driver side of my 2016 Camaro 2SS. You can pretty much hear it at any speed, but is heightened when starting up and when you hover over small bumps including speed bumps. Please have a look at the video: https://youtube.com/shorts/lVn8Xq8Jl4U
I’ve been trying to figure this out for weeks now. I also really don’t want to do unnecessary repairs only do the sound to not go away. I really appreciate all the help.
BossMS is offline   Reply With Quote
Old 07-07-2021, 09:57 AM   #2
SnowWhiteSS
Drives: 2017 Camaro SS
Mine does the same thing. It’s not constant when cruising like that. But it’s when the car is flexing. Speeding up, slowing down, making turns, Ect. I just drown it out with music. Here’s a video of what mine sounds
https://youtu.be/r8TMKmy3o2A
SnowWhiteSS is offline   Reply With Quote
Old 07-07-2021, 01:25 PM   #3
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
Does turning on the A/C make it better for you guys?
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 07-07-2021, 03:46 PM   #4
BossMS
@arpad_m Thanks for the post. No, the sound comes regardless, whether the A/C is On or Off. I think it is coming from two parts hitting against each other. What I don't understand is how can that be possible when I start up the car, do you guys think it's the exhaust tips?
Old 07-07-2021, 03:59 PM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Obvious rattle is obvious.
Check the plastic covers on the bottom of the car, then take them off and check for loose things. Fuel lines, exhaust pipes heat shields hangers AFM valves, wiring. Fuel tank attachments, etc. Also check in the DS rear speaker & hole for loose things.
After all of that, DS rear suspension & brakes, trunk DS side modules, etc. Make sure the tow hook isn't rolling around in the trunk.
Gunkk is offline   Reply With Quote
Old 07-07-2021, 10:29 PM   #6
arpad_m
arpad_m's Avatar
Ah, okay, I see, initially I thought it might be the pressure vent beneath the quarter panel that has caused a similar rattle-y sound on some cars.
If no plastic trim piece is loose and no clips are broken in the rear and you verified everything Gunkk mentioned, another potential candidate is the infamous NPP rattle, if you have the dual mode exhaust option (you can tell from quad exhaust tips). The fix for that is described in this GM TSB that I applied myself with complete success.
735 rwhp | 665 rwtq
Old 07-08-2021, 12:12 AM   #7
BossMS
That’s a lot of things to look into. I appreciate the insight and will begin looking into them one by one. Will update if I am able to troubleshoot the issue.
Old 07-08-2021, 12:15 AM   #8
BossMS
I do have the NPP exhaust and the statement looks promising, however GM notes that the sound is caused in the right rear exhaust control valve actuator; as we can hear in the video, the sound is coming from the left rear side (driver’s side). Does this makes sense?
Old 07-08-2021, 10:00 AM   #9
arpad_m
arpad_m's Avatar
Well, the NPP valve and actuator parts are the exact same design on the left and the right, I don't see how only the passenger side would be affected. IMO it's more likely that GM came out with a bulletin after the first few instances and never updated the description.
I'm not saying this is definitely what you're hearing, but it's a valid possibility. This one is easy to check from outside the car, too.
735 rwhp | 665 rwtq
Old 07-09-2021, 04:38 PM   #10
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
A few things, get a buddy to ride in that seat and try to isolate it...it'll sound different from the drivers seat. Check under the trunk for somethign loose. Gently fist(!) bump the interior and exterior body panels and try to replicate the noise. Lastly, get under it and start poking around.
that's not the known NPP rattle or problem.
WhiteMale is offline   Reply With Quote
Old 11-29-2021, 09:00 PM   #11
smokeybrown
Lowe's Pro
smokeybrown's Avatar
Drives: 2022 LT1
Bossms, ever figure this out? Same problem here.
smokeybrown is offline   Reply With Quote
clanking, help me, weird sound
