11-10-2022, 05:40 PM | #1 |
Drives: 2013 ZL1 Join Date: Nov 2018
Mag Ride alternative.........
I am getting them off my car, I have spoken to Sam Strano about it. I was going to put Koni Yellows on the car but the fronts aren't available.
Mine are failing, the car rides like a tomato wagon. Seems the 5th gen does not have any aftermarket support. These Ridetechs have a million mile warranty and are rebuildable, per Sam for turning and handling they may be a good route for $2400. Anyone else gone this route? https://www.ridetech.com/product/coi...-series-gen-5/
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
11-10-2022, 08:27 PM | #2 |
I would not give my Mag ride ride for anything!
11-11-2022, 06:25 AM | #3 |
When they fail(and they will) and you can no longer get them(like now with the fronts, you can't get them) What will you do? I've already replaced them once.
11-11-2022, 02:16 PM | #4 |
Drives: 2014 ZL1 Join Date: Jun 2009
You’ll have to eventually lol.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
12-14-2022, 09:37 PM | #5 |
Learner of things
Drives: 2013 ZL1 M6 coupe, black Join Date: Dec 2017
QA1 makes a reasonably priced dual adjustable front strut kit for our cars. I have them on mine and while they're not fancy or pricy, the adjustability helps keep the weight on the rear wheels through the shifts. I run 10% rebound and about 75-80% compression.
2013 M6. Cammed, straight piped, 17# boost, E85. Tuned by CHenry Motorsports. 825rwhp @ 6450, 812 rwtq @ 3500. Stock unported blower, stock heads, stock bottom end, stock throttle body. Boost only, no meth, no nitrous
12-15-2022, 10:20 AM | #6 |
1000hp is NEVER Enough!
I will be going with the Air Lift Performance air ride when mine die.
https://www.airliftperformance.com/v...vrolet-camaro/
1,000hp IS NEVER ENOUGH!!!
12-16-2022, 11:36 AM | #7 | |
Never Satisfied
Drives: 2012 ZL1, 2017 Challenger Scat Pack Join Date: Nov 2014
Installation and set up cost?
2012 ZL1 A6 -stock for the moment, Go Mango Challenger Scat Pack Track Pack A8, 2022 Go Mango Hellcat Redeye Challenger, 2000 WS6 - M6, 433 RWHP, 405 RWTQ - SOLD
12-16-2022, 04:40 PM | #8 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
12-16-2022, 07:28 PM | #9 | |
I can do the install and then wrecker it to a shop and get it aligned. Setting ride height is a PITA and should really be done with a set of scales(which I have access to). I have a good shop that can align it. Fine tuning the shock settings is on you and how you like it to feel. No way in hell I'd put air ride on my car, I like it to turn with a lot of lateral grip.
12-17-2022, 01:00 PM | #10 | |
Never Satisfied
Got It
12-21-2022, 10:25 PM | #11 | |
I hate to say it, but I cannot wait for the magride struts to fail...
12-21-2022, 10:46 PM | #12 | |
01-16-2023, 01:55 PM | #13 |
Drives: Chevrolet/ ZL1 Join Date: Oct 2022
01-16-2023, 07:04 PM | #14 |
You need a decoder ring? At present you cannot get mag ride front shocks. Not far in the future you won't won't be able to get them at all as GM is the only one who makes them and they will discontinue them.
