Old 12-10-2013, 12:19 AM   #1
SKANLEZ
SKANLEZ's Avatar
Drives: 2000 Camaro SS
Seller says 2nd gear slipping!
Just need some advice. I plan on looking at a 2000 Camaro SS Automatic and the buyer says that 2nd gear is out meaning that it slips when the car goes into second gear. Is this a sign that the transmission needs to be replaced or can it be something else?
If its the transmission, how much would it cost to be rebuilt or replaced? Thanks in advance for everyones help.
2010 Camaro SS
Mods
Custom Hood
Black Rear Berger Panel
Magna Flow Exhaust
Hurst short shifter
ADM cold air intake
Pedders Drop Springs (1.0/1.5)
Niche Apex Wheels 20x10.5 all around 35+ offset
315/35/20 rear and 275/40/20 front tires
Red Calipers
SKANLEZ is offline   Reply With Quote
Old 12-11-2013, 12:04 AM   #2
speedmon
Drives: C6 Z06
How many miles?
What color is the fluid?
Most likely needs to be rebuilt...cost all depends on your connections.
Could be anywhere from $800 to $3000...for the same rebuild....there's only so many ways to rebuild a 4L60E. It just depends on how much the mechanic thinks you know and how to shop for a rebuild.
speedmon is offline   Reply With Quote
Old 12-17-2013, 10:35 PM   #3
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
Likely the tranny is out, just picked up one with the same problem. I would plan on 1500-2000 for a good 4l60E and at which point it would probably be beneficial to go with a high stall torque converter another $500. You could also go with a 4L80E swap for about 3500 if you want to build it up with quite a bit of power.
It all depends on what you want to do, mine kinda snowballed, I pulled the tranny and decided with how much of a pain it was to get out I ended up getting a tq converter, tci flex plate (which I think is a must even if staying stock as the factory flex plates were weak), tq arm, tranny mount, motor mounts, deep oil pan, headers and added a tranny cooler to help it live longer. I figured I would replace all of this at once since I already had it all out. It turns out a $1500 repair turned into a $3000 project.
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
Old 12-18-2013, 09:27 AM   #4
PHXLT1
PHXLT1's Avatar
Drives: black Z28
If you can't afford the rebuild then you can go the junkyard. Or private seller route. I did and my trans lasted 8 years so far. I'm just now dealing with TCC sensor now but 8 years is not to bad for 350 bucs. Now you may or may not last that long but at least it will buy you some time till you can save for a rebuild. 4l603 are all over so it shouldn't be hard to track one down cheap.
My family
1994 Z28 (mine)
2015 Camaro (wife's)
2015 Silverado (mine!)
54 Belair (wife's)
2004 silverado (daughters)
PHXLT1 is offline   Reply With Quote
