Gen5DIY
Old 05-02-2018, 10:27 PM   #1
Zee-Ell-One
YOOZ GOTA B FREKN KIDN ME
Zee-Ell-One's Avatar
Drives: 2013 6mt ZL1#826
Please Help!! 2013 ZL1 LSA Powered Misfire/Pop Problem
I have an intermittent misfire/hesitation on my 2013 LSA powered Camaro ZL1. Only mod is a Hooker cat back 3" dual exhaust with xpipe no mufflers and a K&N drop in filter no tune.
It seems to be limited to and occur only after a long coast down a canyon with sustained low RPM engine braking. When it's time to accelerate again seems if I give it a decent amount of throttle starting from 2000 RPMish and put a good load on it I get a Misfire/Pop at about 3000 RPM. Then it seems to be okay again until I repeat a similar scenario.
Any ideas, suggestions, solutions would be much appreciated.
The Zeldabeast! A True Road Warrior!
2018 Dodge Challenger Hellcat WideBody 6MT
2013 ZL1 Camaro 6MT
2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab
2012 Aprilia RSV4 R
2015 Husqvarna FC450 Motomadness
First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter
Zee-Ell-One is offline   Reply With Quote
Old 05-03-2018, 06:32 AM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Dirty MAF sensor, cracked plug or wires, bad fuel or delivery.
JB'sZL1 is offline   Reply With Quote
Old 05-03-2018, 11:32 AM   #3
VRZL113
VRZL113's Avatar
Drives: 2013 ZL1, M6
Are u actually logging a misfire, or are you assuming this because of the popping sound.
I'm willing to bet it is un burnt fuel in the exhaust system firing off when you give it throttle after deceleration.
With no mufflers, and a larger exhaust without a tune, I'm sure you are running a little richer than ideal.
#3257 | Wix 49651 | Gates K080660HD (Green Belt) | ACDelco UPF48R | Mild2Wild
VRZL113 is offline   Reply With Quote
Old 05-04-2018, 01:48 PM   #4
NVRL8 ZL1
W8NN4U
NVRL8 ZL1's Avatar
Drives: '13 ZL1 A6
Mine did that when I pulled the fuse. There is a deceleration table that regulates the fuel during that period. You can have it tuned out if you don't like it. Once I did the headers, the popping snorting sounds were even louder...
NVRL8 ZL1 is offline   Reply With Quote
Old 05-05-2018, 12:28 AM   #5
Zee-Ell-One
Thank you for your response!
I am not logging a misfire I don't have that telemitry capability yet. The pop is accompanied by a hesitation so it's definately a disruption in the cylinder combustion process.
I do have more black soot at the tailpipes between washes than before the exhaust swap. Does opening up the exhaust typically induce a rich condition? Is a misfire a symptom of being too rich? Is a rich condition harmful to the engine or is too lean harmful or both?
I'm full of these questions because I'm a novice DIY mechanic. I have a pair of long tube headers in the box waiting to be installed and that is why I have been stalling on getting a dyno tune.
Any and all advice is very much appreciated. Thank you Forumers.
2013 ZL1 Camaro 6MT
2012 Aprilia RSV4 R
Old 05-05-2018, 01:23 AM   #6
Zee-Ell-One
It's not the deceleration crackle. It actually hesitates and pops upon acceleration. I assume you are talking about having pulled the exhaust valve fuse? Did your car actually misfire and hesitate?
2013 ZL1 Camaro 6MT
2012 Aprilia RSV4 R
Old 05-05-2018, 01:27 AM   #7
Zee-Ell-One
Do you have experience with this on an LSA engine? I did change the plugs today but haven't driven it yet.
2013 ZL1 Camaro 6MT
2012 Aprilia RSV4 R
Old 05-06-2018, 07:50 PM   #8
Zee-Ell-One
I changed the plugs and solved the problem thanx! Runs stronger especially on low RPM also idles better and fuel mileage increased. At only 18,000 miles the plugs were shot they looked pretty bad compared to a new plug. I must admit my 18,000 miles is probably more equal to 50,000 miles from a daily driver. There was alot of wide open throttle driving in those miles.
2013 ZL1 Camaro 6MT
2012 Aprilia RSV4 R
Old 05-07-2018, 01:13 PM   #9
NVRL8 ZL1
W8NN4U
NVRL8 ZL1's Avatar
Drives: '13 ZL1 A6
That's great you fixed it. The answer to your questions would have been, yes with the fuse pulled, no to the miss fire/hesitate, and yes, I found I have much more soot on the tips. I have a DIY mild to wild switch, and I leave it open 90% of the time.
And get those headers on, the car will sound fantastic....
Old 05-08-2018, 11:21 AM   #10
VRZL113
VRZL113's Avatar
Great news. Glad you got her fixed.
Keep in mind, running too rich can eat up plugs. Were they all black and sooty looking?
Not saying this is def what happened, but I'd keep an eye on everything. Un-tuned with exhaust mods, can change up the air/fuel mixture some.
