07-16-2018, 04:20 PM | #1 |
Drives: 2011 2ss 6 speed MT Join Date: May 2018
Strange feeling when shifting and clutching 6SP MT
Hey all,
I have a 2011 6SP MT Camaro 2SS. When I move my shifter into gears they all feel really bumby, maybe notchy would be the better word? im not sure but it feels hard to push it all the way into gear. also lower RPMs like 800-1.2k 5-7 MPH in first gear feels sort of like the car will rock back and forth and make some sort of like clanking sound this also seems to happen sometimes in second gear at lower RPMs. Sometimes when shifting and then releasing the clutch after up shifting it will sort of jerk i'm not sure if this is user error or not.. it tends to not do it as much if i let out the clutch very slowly almost riding it. Lastly i'd like to know how damaging it is to the clutch for me to start off in first gear by just slowly releasing the clutch to make the car move. Thanks for reading. |
07-16-2018, 05:26 PM | #2 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
Totally normal for these. In cold weather until the trans warms its tough to get in first. Idling in first gear the car will buck. Basically I get it going and push the clutch in and coast or give it some gas. At times you just cant stop it and just push the clutch in and let it settle a second and let it back out. You will get the hang of it.
07-16-2018, 05:41 PM | #3 |
Drives: Camaro V6 Join Date: Oct 2016
With all that V8 torque, can't you start off in second gear? Heck, I can even do that in my little V6.
07-16-2018, 05:45 PM | #4 |
07-16-2018, 05:48 PM | #5 |
Drives: Black camaro 2ss 45th Join Date: Jan 2018
Look into redline d4 atf for the trans if you want to really smooth out that shifter feel. Look it up. Everything else you stated sounds totally normal
07-16-2018, 06:53 PM | #6 |
07-16-2018, 07:14 PM | #7 |
Take out top plug. Take out low plug drain. Install low plug back. Pump new fluid in til drops out top plug hole. How hard is that?
Life is short, drive it like you stole it! |
07-16-2018, 07:24 PM | #8 | |
Drives: Miss Con Ception Join Date: Aug 2016
Why not? I start in 2nd almost all the time. I can just roll my foot off the clutch. No need to ride it.
2011 1SS/RS LS3 CGM
07-16-2018, 07:44 PM | #9 |
07-16-2018, 07:45 PM | #10 |
07-16-2018, 10:23 PM | #11 | |
That is correct.
2011 1SS/RS LS3 CGM
07-17-2018, 10:25 PM | #12 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Also take off in second here most of the time when in normal traffic. Give it a little gas, hear it roar and - as mentioned - roll off the clutch... nothing wrong with my transmission after many many miles of road...
07-18-2018, 08:36 AM | #13 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Definitely recommend changing the trans fluid. And maybe your brake / clutch fluid? I remember seeing your other thread, your car has like 51k on it right? I dunno if your car is modified or if you're the original owner but maybe it's time for a better clutch? Or an upgraded master cylinder.
Biggest thing is maybe the car doesn't need any of it but it might make you feel better, which is a big deal. Lol.
07-18-2018, 09:24 AM | #14 | |
I wasnt aware there was a clutch fluid? |
