Old 03-16-2018, 04:14 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question trans mount
ok so has anyone made a trans mount yet? ive tried the rev shift one but it causes bad vibrations and gives me false knock readings constantly.
stock trans mount isnt holding the tans straight when i have the car turned up. if i leave on gate pressure its ok. if i turn it up the car feels like im on a rumble strip until the car picks up speed.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 03-23-2018, 05:32 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Try a 1LE/Z28 mount.
Orange Krush II
Old 03-23-2018, 05:39 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
The combo of Z/28 engine and trans mounts are reported to be stiffer yet compliant enough to daily drive. That's my plan is to run those vs aftermarket offerings.
Sent from my SM-G935V using Tapatalk
Firefighter is offline   Reply With Quote
Old 03-26-2018, 01:52 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The part number (20952439) for the Z/28 is the same as:
Old 03-26-2018, 07:39 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
I like the rigidness of the RevShift; however, I do have a dandy harmonic at around 1500rpm that is a rather annoying "loud bearing" sound noise. I do not get any false knock though. When you find a good aftermarket mount, definitely let me know too.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
