03-31-2018, 02:43 AM | #1 |
Drives: 2013 and 1971 Camaro RS SS, Join Date: Jul 2015
Do I need end links?
How’s it going guys, I just purchased the stage 1 suspension from Hurst, which is lowering springs with upgraded sway bars, my question is do I need upgraded end links or will the stockers suffice? And also what other issues/tips should I look for as this is the first vehicle I’ve ever lowered, and driven. Thanks in advance.
03-31-2018, 06:11 AM | #2 |
USA-1
I'm going for a mostly handling build and I'm not worrying about upgrading the endlinks. I would grab some 1LE toe rods, and either a Z/28 or BMR UCA, AND, if you haven't upgraded the rear subframe bushings to solid, you should!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
04-02-2018, 01:32 PM | #3 |
But as far as initial installation, I don’t need any upgraded parts to fit the new parts
04-02-2018, 01:55 PM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
The factory front and rear end-links/drop-links are fine for even the biggest, baddest sway bars out there...
04-04-2018, 12:59 AM | #5 |
04-04-2018, 01:02 PM | #6 | |
Drives: Race Car Join Date: Sep 2009
04-04-2018, 03:05 PM | #7 |
I'm certainly no expert, but just because the factory links are weaker than those doesn't mean they aren't strong enough . I don't have much experience driving this car to its limits but I've never yet heard of a front (or rear) link bending or breaking, but then again what do I know
04-04-2018, 03:12 PM | #8 | |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
04-05-2018, 10:03 AM | #9 | |
Also have seen bent & broken rear Trailing Arms & Toe Rods |
04-05-2018, 10:09 AM | #10 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
If you push anything hard enough, it will break. But, yes, the fronts at minimum.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-05-2018, 11:12 AM | #11 |
Nice... Well I guess that begs the question for the OP: how hard will the car be pushed?
04-13-2018, 11:49 AM | #12 |
I think I might just research some end links, since I’m gonna be changing things
