08-26-2017, 02:15 PM | #1 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
Burning smell
Hey guys! 2016 2SS M6.
So, lately I've been noticing a burning smell coming from the car, windows down or up. It only occurs when the car is at a stand still, and is more prevalent when going up hill. My initial thought was the clutch, but after driving around last night with a friend, who has only ever driven manual transmission cars, he said otherwise. He believes the smell is oil related. So we checked the oil pressure and temperature, pressure floated between 30-40psi, and temperature never exceeded 200 F. About 200 miles back I did have an oil change. 10qts of mobil1 full synth, and an AC delco filter. He thinks it's possible that the smell could be from oil spillage on the headers, which would explain why the smell only occurs when the car is sitting still and warmed up. Dipstick reads full, oil color is new. What are your thoughts guys? I'm planning on getting the car up on ramps before I drive it again. Anything I should look for? If a spill is located on the headers, what should I use to remove it? Alcohol? Dish soap? Thanks guys.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
08-26-2017, 04:17 PM | #2 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
This is often caused by some plastic that melted onto your exhaust somewhere.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
08-26-2017, 04:27 PM | #3 | |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
12-28-2017, 07:59 AM | #4 |
I’m going to bump this. I’m having the same issue but no clear leak. I did have a pinion seal leak that was repaired. I cleaned off the exhaust (even down to sanding the pipes down) and any residual that was in the area. Condition didn’t change. Not seeing any puddling anywhere. I’ve had it in twice and they don’t know where to start looking or what to do with it but acknowledge the burning oil smell in the car. I just came from service again and me, the tech, and service manager we’re all under the car with flashlights looking for anything but came up with nothing.
2017 ZL1 A10 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
12-29-2017, 09:25 PM | #5 |
SoCal HT5! SD
Changed my oil again a few days ago. Did not spill any oil anywhere. Same oil as the last change, M1 full synth. Burning smell when stopped has returned. While its not so bad anymore, it is definitely from the oil change as the smell only occurs for me after I change my oil. I must be doing a messier job than I think.
Maybe residue burning off the outside of the PF64 filter? I may have forgotten to wipe it down. gpskinzhut, do you notice it after an oil change?
12-30-2017, 02:28 AM | #6 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
I’d say it’s from the oil change. Changed mine and spilled the tiniest amount....the funnel moved some during filling. Anyway; mobil 1 is good stuff and does not burn off easily (but will smell). This lasted for at least 1500 miles after the change.
12-30-2017, 02:28 PM | #7 | |
12-30-2017, 07:54 PM | #8 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Mine has a smell after I changed the oil. I only assume I made a mess. It will have to stop eventually.
12-30-2017, 08:27 PM | #9 |
SoCal HT5! SD
It will stop. Mine did after about 500 miles.
12-30-2017, 10:12 PM | #10 |
Mines always done it no matter how neat I am. It leaves after 5-600mi. No worries.
2010 2SS Camaro (sold) 2010 ZL 427 Camaro (sold) 2012 ZL-1 Camaro (sold) 2018 ZL-1 Camaro |
12-31-2017, 12:50 PM | #11 |
Drives: ///M3 Join Date: Nov 2016
Mine too
12-31-2017, 10:26 PM | #12 |
almost 1400 miles on the last oil change and still smelling strong.
01-01-2018, 04:59 AM | #13 |
Maybe it is dripping some where. Or oily finger prints on the exhaust.
Soleil
01-08-2018, 12:58 PM | #14 |
Drives: 2017 2SS Hyper Blue Join Date: Jun 2011
Anyone ever find out a cause on this? My 2017 has done this since new. Come to a stop or back up into my driveway and I get the burnt oil smell.
First oil change done and still the same issue. We looked everywhere no wet spots anywhere. |
