01-03-2019, 07:04 PM | #1 |
Drives: jjj Join Date: Dec 2018
zl1 fuel pump vs zl1 fuel pump sending unit, what's what?
I ordered a Zl1fuel pump at LKQ today for $75. my question is that I don't know if its possible for them to remove just the pump off the sending unit, I don't know if they are going to send me the whole sending unit or just the fuel pump. if they send me the pump can it be mounted on the SS sending unit?
I'm in process of doing an E85 conversion with not too much HP so don't need much fuel. I'm at 361HP. Once I do the zl1 fuel install will I be able to drive it till I get the stock SS FCPM flashed trough hp runners to run the new zl1 pump? |
01-03-2019, 07:58 PM | #2 |
Bump.
01-04-2019, 07:34 AM | #3 |
Drives: 2014 SS 1LE Join Date: Apr 2014
I would imagine that it should work. When i removed my ZL1 pump the sending unit came off with 2 bolts i believe and i just reattached it to my dual pump setup. The SS sending unit should be able to be attached to a ZL1 pump. You should also be able to drive it until you get the fpcm situation handled. Just wont see any benefits of the new pump.
01-04-2019, 12:30 PM | #4 |
understood. Do you know if I need to flash my stock SS FPCM to run with the ZL1 pump or tune the FPCM?
01-04-2019, 01:55 PM | #5 |
I dont want to give you the wrong information on that part so i cant say for certain.
01-04-2019, 06:28 PM | #6 | |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
https://dsxtuning.com/pages/about
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
01-04-2019, 06:42 PM | #7 | |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
01-06-2019, 07:12 AM | #8 |
Drives: 10 2ss/rs Join Date: Jul 2018
With a stock fpcm wont the zl1 pump act the same as a stock ss pump
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
01-08-2019, 12:47 PM | #9 | |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
A few years back, you had to get a new module (i think ADM made them) but nowadays, HP Tuners can make your stock SS FPCM work
Bone Stock |
01-13-2019, 09:03 PM | #10 |
Santos
Drives: 1SS Blk 6M ECS 1500 Join Date: Jul 2007
Is there a more specific post relating to tuning with HP. Going in for a retune soon and was trying to get some more info for my tuner
01-14-2019, 08:43 PM | #11 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
HPTuners.com. Forum
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
