Old 11-09-2013, 11:59 PM   #1
Crazycoot
Drives: '13 ZL1 M6
Elm-327, iPad mini, and permanent mounting
Thinking of installing the elm 327 wifi obdII reader in my car and then mounting an iPad mini on the windshield with this ram mount: http://www.rammount.com/CatalogResul...5/Default.aspx
This would allow for a pretty cool real time display of all the engine stats and also allow me to quickly clear any codes caused by my midpipes. What do you guys think of this setup?
Crazycoot is offline   Reply With Quote
Old 11-10-2013, 09:55 PM   #2
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
Did you try placing it on the dash to see how good it does as a HUD? Try Torque in HUD mode and check it out. I did with an Android tablet and it looks pretty cool at night.
There are also mounts out there that hook into the front heater vents to hold tablets.
If you see it, get it, for tomorrow it may be gone!
rray is offline   Reply With Quote
Old 11-11-2013, 10:33 AM   #3
Crazycoot
Drives: '13 ZL1 M6
Is the entire windshield coated to reflect data or is only the area around the OEM HUD coated? I actually wanted something where the passenger could read the data as well in cases such as track days or simply to impress passengers. If I placed the ipad mini where the current HUD is, the passenger could not see the data. Also, I have an iPad mini and Torque doesn't work with apple products. Thats why I was looking at the "engine link" app.
Old 01-30-2014, 03:16 PM   #4
hiddenangels89
hiddenangels89's Avatar
Drives: 2012 SS Camaro L99
Mine is android, but the mount works all the same.
I wouldn't recommend it in the window because of how much space it takes up... personally.
hiddenangels89 is offline   Reply With Quote
Old 11-02-2018, 11:09 AM   #5
KI4NPZ
KI4NPZ's Avatar
Drives: 2014 1LS Silver Ice Metallic
I temporarily mounted my iPad above the radio, thinking it would be nice to have easy access to my music library while being easier to see and interact with than the phone. Personally I found it a little too big, and I’m thinking the iPad Mini might work better. A little spendy considering it’s potential single purpose—but I think it would fit nicely in our no-so-big interiors.
And also the phone is too small to use effectively to monitor parameters with Torque/DashCommand as well so I think the mini would be better for that as well
KI4NPZ is offline   Reply With Quote
