09-12-2022, 07:50 AM | #1 |
Drives: 02 Dakota - 2011 camaro 2ss Join Date: Jun 2019
Transmission fluid recommendations
Im looking to change the transmission fluid and filter on my 2011 Camaro 2ss automatic l99
What fluid do you recommend and how many qts will I need.. thanks |
09-12-2022, 08:33 AM | #2 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
I just purchased the AC Delco Dexron fluid from rockauto. I'm not a mechanic or chemical engineer; just a guy driving a camaro. I try to stick OEM as much as possible. Your safest bet would probably be to grab some from your local dealership, but that will cost you more.
As far as the amount, you should check your owner's manual. I drive a V6 auto, and it took a little over 6 quarts if I recall (don't quote me on that). I did the temperature level set rather than the drain-and-replace-with-same-amount method. |
09-12-2022, 09:26 AM | #3 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
09-12-2022, 11:38 AM | #4 |
Ok thank you I’m gonna buy some and have my local mechanic put it i. Gonna do the differential too
09-12-2022, 11:50 AM | #5 |
Most people will tell you the AC Delco Dexron is best, and in most cases I would agree.
Problem for me is that I cannot run that in my car without issues. The Delco fluid produced a terrible 2-3 shift flare whenever I ran it. I was able to completely eliminate it by running with Valvoline Max Life full synthetic ATF. Not sure why or what the difference is. I am not recommending anyone else do the same, just stating what worked and didn't work for my trans.
09-21-2022, 08:21 PM | #6 |
'It's an experiment'
Factory for me - I have a GPI modified setup with a ZL1 torque converter - road raced it. I also have a trucool 44k trans cooler for that...
Never tried the Valvoline Max but it may be a good option... -Don
747 RWHP 794 RWTQ
09-22-2022, 07:18 PM | #7 |
Redline
Life is short, drive it like you stole it! |
09-22-2022, 08:20 PM | #8 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Mobil 1 HV LP.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
09-23-2022, 06:53 AM | #9 |
That is not the correct transmission fluid for his Camaro. Fluid usage is as follows:
6L80 uses Dexron VI 8L90 uses Dexron HP 10L80 uses Dexron ULV Why do they use 3 different fluids in 3 different transmissions? Use the wrong one and chances are you will find out! |
Thread Tools | |
