11-26-2010, 11:15 PM | #1 |
Drives: 2010 Camaro SS RS Black Join Date: Oct 2009
Intermittent oil leak; Needs to be a STICKY
ATTENTION everyone my 2010 Camaro 2SS RS that I have had for 11 months, with only 2758 miles on it, I noticed about a week ago a small spot of oil under my Camaro, could not find the source; took it to the local dealership, thinking that just maybe it was a small issue while the service writer was typing in my issue she paused when I asked if there have been any other 2010 Camaros brought in for the same issue, then seeing tell tale signs of deception, she lied to me and stated “No.”
45 minutes later she approached me and stated that my car needed a complete oil pan gasket, and then told me that she herself has seen 2 out of 10 Camaros’ for the same issue. I told her make it 3 out of 10 now with mine sitting in the shop all day. I asked her if Chevy or GM is going to declare a recall she stated “No” again and said it is when any customer has their oil change, or they see a leak they will go to their dealership, and the dealership will check the gasket for leaks. Time to demand that Chevy steps up. Information: on my receipt, CAUSE: Found oil pan leaking at rear of engine J1000 pan and/or gasket, oil replace They replaced the following parts: 1; 12612350 Gasket 1; 15203889 Gasket; at bottom of receipt shows increase in cost for this gasket, must be a lot of gaskets going out! 6; 12345885 Oil Under that I have CC: 0327 and FC: 4061 can anyone explain these, so this was my Black Friday.
Well this is it!
2010 Black Camaro 2SS RS, Tint, 3in H pipe back Flow Master Super 10 Series single chamber, CAI Cold air Intake. |
11-27-2010, 02:40 PM | #2 |
The Noob
Drives: 2006 QSM GTO Join Date: Nov 2010
Why would they make a recall? It isn't a safety issue. This is the reason you have a warranty.
11-27-2010, 02:54 PM | #3 |
Drives: 05/07 Chevy's Join Date: Aug 2009
Also we replace oil pan gaskets all the time (on more then just the camaro), so this is nothing new.
11-27-2010, 03:02 PM | #4 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
"Time to demand that Chevy steps up."
are you kidding me??? you have what's called a warranty, because things like this happen. They fixed it...move on with your life and enjoy your camaro. The sky is NOT falling, $hit happens sometimes.
NY5thgen.com
11-27-2010, 03:15 PM | #5 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
I've had 2 oil leaks so far with less than 8000 miles. First was the oil cooler adaptor gasket and second was the oil pan gasket. I hope that's it!
Similar Threads | ||||
Roto-fab CAI, dry filter vs. oil filter | Roto-fab 1 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 0 | 11-12-2010 08:07 AM |
First oil change? | Fogey | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 27 | 09-18-2010 06:50 AM |
ON STAR OIL Life % | T_MECO | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 34 | 04-25-2010 08:55 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
