Old 07-25-2013, 10:37 PM   #1
Phorecyte
Phorecyte's Avatar
Drives: Black 1SS/RS 1LE
Switching to NPP on 1LE SS, What parts are required...
What parts are required for taking an NPP from someone else's car and putting it on my own? When I say from someone else, i mean someone upgrading to something else or even a wretched with an intact exhaust. I'm trying to figure out a cheaper way to get the system than going through the dealership.
Also is it something I could install at home? Are there vacuum lines involved?
Could I buy an NPP system from a third party(camaro owner) and have it installed at dealership to avoid warranty loss?
Phorecyte is offline   Reply With Quote
Old 07-25-2013, 10:43 PM   #2
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
The catback itself will bolt right up. You'll need the rear diffuser for the quad tips and an NPP in a box to control the exhaust mode. Yes, you will need to run vacuum lines.
http://www.camaro5.com/forums/showthread.php?t=247109
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-26-2013, 08:28 AM   #3
flyinlow
flyinlow's Avatar
Drives: 2017 Camaro ZL1
They wouldn't have to run the vacuum lines, just leave them open. They would lose the dual mode, but it would sound nice!
flyinlow is offline   Reply With Quote
Old 07-26-2013, 09:00 AM   #4
FanDamNCSU
Drives: 2010 CGM 2SS/RS - L99
I just recently installed the NPP exhaust on my 2010. The seller said the exhaust was pulled from a 2013 ZL1 - It literally bolted right up. I chose to have it installed at a local shop and it took him roughly an hour but a portion of that was talking with him and watching the process. He had to use a long crow bar to pull off the upper most hangers and he didn't like the way the stock diffuser was installed (plastic snapped into plastic).
I opted not to install the NPP Vaccum kit and try the exhaust wide open. It sounds great and is not overbearing in any way. I get a little sound in the cabin but it's not annoying at all and music easily covers it up. The way my NPP exhaust sounds is how I feel the Camaro should have sounded from the get go - I reccomend it highly.
Performance:
Vararam CAI, Vmax Ported Throttle Body, GM Performance Dual Mode Exhaust (NPP), JRE Tune, Hotchkis TVS Stage 2 Track Pack, Vitesse Paddle Shifters, Vitesse Throttle Controller
Functional:
Hex Vents, Elite Catch Can, WeatherTech Digital Fit Mats, Escort Passport Max
Cosmetic:
Heritage Grill, GM Splash Guards, ZL1 Rockers
FanDamNCSU is offline   Reply With Quote
Old 07-26-2013, 09:32 AM   #5
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I only close my flaps on the highway and thats not because its unbearable in anyway its just nice tohave the option and quiet it down a bit. If installing the vaccuum lines is very difficult or relatively expensive I would suggest avoiding it, you will love that exhaust as Fan stated above its how these cars should sound from go!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 07-26-2013, 11:21 AM   #6
yotaman96
yotaman96's Avatar
With the headers, I prefer the sound with the exhaust closed.
2002 Trans Am
Old 07-26-2013, 06:33 PM   #7
Phorecyte
Phorecyte's Avatar
Ok so it bolts right on, and I would probably just leave it open, so i dont need to do vac line. I don't have to buy the NPP in-a-box thing do I? that just controls if the exhaust is open or not?
Old 07-26-2013, 06:47 PM   #8
yotaman96
yotaman96's Avatar
Why bother getting a dual mode exhaust if you're not going to use it?
2002 Trans Am
Old 07-26-2013, 07:29 PM   #9
the_fast_one
the_fast_one's Avatar
Drives: 2017 red hot zl1
I just installed my kooks and catless connectors and def like it closed while driving around town but it does sound sweet with them open too.
I used npp in a box from http://forums.corvetteforum.com/c6-c...oductions.html
It came with everything needed. I lengthened the wires a foot so I could tuck them better and I bought longer hoses for the exhaust from O'Reillys for 4 bucks so I could run one to each muffler out the trunk.
2017 ZL1 built by GPI. Way to many mods to list 855rwhp/720rwtq
the_fast_one is offline   Reply With Quote
Old 07-26-2013, 08:29 PM   #10
Cody6.2
Drives: 2012 Camaro 2SS
Hate to break it to you but 75% of the car is held together like this. When I took the front end off mine I was surprised how half assed it was.
Cody6.2 is offline   Reply With Quote
Old 07-26-2013, 09:14 PM   #11
Phorecyte
Phorecyte's Avatar
The sound of the NPP over the stock is way better, and I don't really want a really loud after market exhaust bc I just bought the car and have extended warranty. I figure I stick with GM parts they won't hassle me at all. (not that they have the right to if its just exhaust, but i dont feel like even arguing) A used NPP is easy to find and also is much cheaper than getting some new after market stuff.
Having the ability to close them would be nice, but if its all kinds of extra work, i dont really care.
Old 08-17-2013, 04:10 PM   #12
Anaconda
Anaconda's Avatar
Drives: 2013 Camaro 1SS 6-speed VR
I am on the verge of buying the NPP exhaust to retrofit into my 2013 Camaro 1SS. Just to make sure I have everything correct all I need are the 1LE diffuser, NPP exhaust mufflers, and the Mild2Wild kit with perhaps longer hoses? I plan on JUST wanting the ability to switch back and forth between open and closed butterflies. I just love the sound of the NPP mufflers and am hoping this is absolutely all I need.
2013 Victory Red 1SS 6-speed w/ black stripes ordered 8/15/12
Delivered 10/2/2012!
Corsa ZL1 catback exhaust, Black CAI intake with scoop and washer bottle relocation
Anaconda is offline   Reply With Quote
Old 08-17-2013, 06:00 PM   #13
ss1letx
ss1letx's Avatar
Drives: 2013 Chevy Camaro SS 1LE
This is my car stock with the NPP. I love that is can open a close. You can see the valve in the video just above the left tips and watch how much it opens and closes just under the short time of the video. I would take the time to run the vacuum lines. It makes the car so much more livable day to day. In my opinion.
ss1letx is offline   Reply With Quote
Old 08-17-2013, 06:12 PM   #14
Phorecyte
Phorecyte's Avatar
Im getting an axle back NPP, what is the best place to cut/weld the old muffs/ put on new muffs?
