03-13-2022, 03:26 PM | #1 |
Drives: 63' chevy impalaSS , 12'Cam89'Cam Join Date: Feb 2013
2012 camaro low oil pressure
okay so I have a 2012 camaro with 180k miles . I bought it new . I keep getting a warning message saying low oil pressure . should I take it to the dealer and have them do a diagnostic?
03-13-2022, 07:59 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
It needs to be checked by someone.
03-14-2022, 08:14 AM | #3 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
I would find a independent mechanic and go from there. Maybe take a recommendation from a friend or relative that has had good satisfaction from a particular shop.
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
03-19-2022, 09:03 AM | #4 |
well I ended up just taking it to the dealership and they said it was the oil pump relay or something like that . I'd have to check the paperwork . but it hasn't come back on since
03-19-2022, 09:06 AM | #5 |
Drives: 2015 2ss/rs Join Date: Aug 2021
I had to change my oil pump
03-19-2022, 09:07 AM | #6 |
yeah I was glad it wasn't that . how many miles were u at and what did they charge ?
03-19-2022, 09:12 AM | #7 |
I had about 60k and did it myself. I tried the oil pressure sensor but no help. Then I heard the lifters clacking so I know the oil pressure was low. Did all the work myself
03-19-2022, 11:58 AM | #8 |
do you have to take the motor out and tear into it ?
03-20-2022, 07:49 AM | #9 |
I tore into it. It was a project. Had to drop the front sub frame about 3-4 inches and raise the motor as high as it could go. Removed the radiator, water pump, and oil cooler. Loosen and slide the rack and pinion fwd, disconnected the sway bar end links. Then I removed the oil and pan and dampener and timming cover. When I removed the pump I notice that the bypass vale was stuck slightly in the open position bypassing the oil back into the inlet of the pump. I replaced it with a Melling oil pump.
05-08-2022, 09:18 PM | #10 |
Drives: 2013 Chevrolet Camaro LT Join Date: Apr 2022
I just had this come up on mine actually (2013 LT). I haven’t taken it to the dealership yet because everything is booked for so long. For me though, it only shows up when I go over 4000 rpm. Maybe it’s the bearings? Idk much. Any help would be greatly appreciated before someone can look at it.
05-15-2022, 06:08 PM | #11 |
Drives: Camaro ZL1 Join Date: Jun 2021
To be honest, I have the same problem, maybe it's because of low-quality oil or because of a broken oil pump. I think it is worth looking for the problem in this place. I'm thinking of changing the oil and checking the oil supply system, see here https://casperoilchange.com/15w-40-diesel-oils/ best 15W-40 Diesel Oil reviews on oil, maybe you should use a better one.
Thread Tools | |
