07-02-2022, 12:15 PM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
GPI or any Aftermarket Wires, Do i need the Heat Sleeves?
Hi, I had the Heat sleeves on my stock LS3 wires, I just put on a set of GPI Wires and I transferred the Sleeves, the Sleeves I believe made it really hard to get the wires to lock on the plugs as they would hit the header or bunch up on the head. They are on now And I hope I have all of them locked on the plugs it was hard to tell.
If I ever change plugs or have a issue can I leave the sleeves off? My Headers are ceramic coated. Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
07-02-2022, 12:56 PM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I've been running my car with TSP headers uncoated without heat sleeves for going on two years now and haven't any issues. I put on about 8k miles a year and had some cheap amazon wires on there but I just upgraded to TSP wires and still didn't put sleeves on. I think your fine without them especially with coated headers.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
07-02-2022, 06:27 PM | #3 |
I have been running SP long tubes for 9 years now, uncoated and Taylor "409" wires without heat sleeves as long. The Taylor boots seat nice and tight on the plug tip and don't move or rotate.
07-02-2022, 06:59 PM | #4 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I don’t use the metal sleeves; however, I do use summit brand DEI sleeves. Overkill, but it’s cheap enough and it’s still easy to R&R the wires.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
07-02-2022, 09:02 PM | #5 |
I have the DEI Sleeves, they were fine on the stock wires with the metal also, But they were getting in the way with GPI, I did get them on and I put about 100 Miles today and they seemed to stay put. I may take them off the next time I take the wires off for anything.
07-03-2022, 01:09 AM | #6 |
Runs on caffeine
Drives: 2010 Camaro SS Join Date: Apr 2020
Depending on how you drive the car sleeves will be recommended. I abuse my car, heavy throttle for long durations. I have my headers wrapped in DEI heat wrap and high temp wires with heat sleeves and I have already burnt through a few.
Do note that high temperatures will affect your wires. Quick little physics lesson: heat increases a wire's resistance. In other words, as your engine bay gets hotter your wires will not be as effective, the hot wires will make it so that the flow of current will be slower from your coil pack to your spark plug. |
07-03-2022, 07:45 AM | #7 |
Drives: ZL1 Join Date: Dec 2016
I do not use the sleeves have 2 inch ARH headers using MSD plug wires no issues.
