08-12-2012, 12:03 PM | #1 |
Drives: 2LT/RS coupe M6 IBM Join Date: Nov 2011
Acid rain etching HELP
I need some help/advice from the paint gurus. My car is an '12 IBM, and I 've had it 9 months. It is garage kept and driven about 20 days a month usually only in good weather, occasionally in the rain. The day it came home it was washed and waxed. Within two weeks it had a coat of Klasse Polish (red bottle) and Sealant (silver bottle), as well as Souvain paste carnuba on top. This has been my standard regimen for the car about every two to three months. I noticed today that I have what appears to be acid rain etching spots. My questions are. What have I done wrong? How do I correct it? Is the paint that crappy?
08-12-2012, 01:29 PM | #2 |
Drives: 2012 Camaro LT Join Date: May 2012
I have the same problems, except mine isn't acid rain. Mine is just normal water from what I can tell. From what I've read around the forum is that the paint job is that crappy and you're not going crazy. If you find an answer be sure to post it.
08-12-2012, 06:52 PM | #3 |
Drives: 2011 Red 2SSRS A6 Join Date: Jan 2011
Does it look like little white dots? If so I just started using adam's wax and it got all of the spots on my car off.
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
08-12-2012, 08:12 PM | #4 |
Drives: 2011 Black RS/SS Join Date: Feb 2012
I've used a 1/2 cup per gallon solution of white vinegar and distilled water in a spray bottle. Worked like a champ. Wash and wax the car afterwards.
08-12-2012, 09:07 PM | #5 |
Thanks, I'll try that.
08-12-2012, 09:34 PM | #6 |
Thanks I will definitely try it
08-12-2012, 10:28 PM | #7 |
Clay it. Then polish it out. U can't stop water etching, if it is not dried right away.
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
08-12-2012, 10:32 PM | #8 |
I have a 2011 IBM and I also had an issue with the paint on the roof of the car. I thought it was acid rain. Only had the car for 3 months when I noticed it. I brought it into my dealership and they would not cover it under warranty. Went to my dad's show. We wet sanded it and polished it out. Afterwards it looked good again and couldn't see the spot. However, this year I have noticed that the exact same spot has come back again.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
