04-29-2021, 01:52 PM | #1 |
Drives: 2010 Camaro SS Join Date: Oct 2020
CAM Pin broke/pushed into CAM core GPI VVT
This is the latest issue on my VVT CAM install on my L99. Apparently I did not get the CAM dowel pin aligned properly with the CAM phaser/gear this damaged the dowel pin causing the cam to spin freely when I try to remove it. Has anyone ran into this issue before? I'm considering putting a couple 1/4 steel rods throught the hole just above the cam under the timing chain cover(picture attached)to hold the CAM still so I can get it off. I don't like the idea but not sure what else I can do...
Hopefully someone has ran into this before.... Sent from my SM-F916U using Tapatalk |
04-29-2021, 04:18 PM | #2 |
No, no issues here with a 2015 install.
04-29-2021, 07:28 PM | #3 |
put the pushrods and rocker arms on and snug them down. That will help hold the cam in place. THen use an impact gun to remove the cam gear/phaser bolt.
04-29-2021, 08:55 PM | #4 | |
04-29-2021, 08:57 PM | #5 |
04-29-2021, 09:32 PM | #6 | |
04-29-2021, 10:00 PM | #7 | |
04-30-2021, 03:44 AM | #8 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
for sure. Makes me glad I paid a good shop to do mine. lol. And I would definitely keep the vvt.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-30-2021, 05:35 AM | #9 |
Drives: 15 Camaro SS Join Date: Oct 2018
Lol. Keep at it though. The results are very much worth it
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-01-2021, 09:25 AM | #10 |
So my buddy wants to tack weld the cam dowel pin to the phaser gear. What are your thoughts on this? Said it will insure alignment and help the pin stability. What are the thoughts on this? I feel like it will be tough to get the timing chain back on.
05-01-2021, 02:20 PM | #11 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
If that was what is needed it’d come from factory like that.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
05-04-2021, 12:01 AM | #12 |
How'd you figure out it was the dowel pin? If you tack weld the gear to the cam, the gear has to be perfectly perpendicular to the cam at all angles. Or else the gear could have a slight wobble that could cause engine damage when spinning at max RPM. I don't think it's a good idea to tack weld. You don't want to chance it.
Be careful when doing the dowel rod trick. I had 2 wood dowels all the way in on my L99 cam swap and 2 lifters passed the dowels and started to fall. Luckily I saved it, but remember that the dowels are not fool proof. I was using 5/16" round wood dowels.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
05-04-2021, 09:23 AM | #13 |
Haven't heard from you in a while how's everything going?
05-04-2021, 09:31 AM | #14 | |
Troubleshooting I took the cam phaser out. You can see (picture) where it either popped out of the hole on the gear or I never had it lined up correctly. Sent from my SM-F916U using Tapatalk |
