05-04-2013, 01:31 PM | #1 |
Ready...Set...Gone.....
Drives: 10' Camaro SS/RS "Stacy" Join Date: Jan 2011
I got cammed
So guys just picked up my car and i have to say the power is great, but i have a small problem if its a problem. The car is fine at idle normal chop, but once i hit the highway and go above 60 mph the car starts to vibrate hard, i don't know if this is normal since i never added a cam to a car before. Also i did the conversion from l99 to ls3 and added 3.91 gears.
update: Got the car fixed it was the driveshaft like "Litle88" said and once they fixed it car was running better. Also the 3.91 gears makes a big difference just saying. Thanks guys, Video:http://youtu.be/fh6Xl4hio6
05-04-2013, 01:36 PM | #2 |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
Not normal at all...
05-04-2013, 01:36 PM | #3 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Should not vibrate. Take it back....
05-04-2013, 01:38 PM | #4 |
Drives: his wife crazy buying mods Join Date: May 2012
Listen to these guys.
What could possibly cause that bad of a vibration?
Gone But Not Forgotten
05-04-2013, 02:05 PM | #5 |
V8 Lounge member #2
His Rearend not set up correctly? Driveshaft not on right?
Any Susie suspension work done? If so alignment might be in order.
05-04-2013, 03:19 PM | #6 |
You sir are correct the driveshaft was the problem, its getting fixed as we speak.
05-04-2013, 03:24 PM | #7 |
Driveshaft was my first thought when I just read your thread, glad they found it right away, post some video when you get a chance.
05-04-2013, 03:34 PM | #8 |
Sure will ill add a start up and when on the dyno for you guys! Thanks
05-04-2013, 04:01 PM | #9 |
V8 Lounge member #2
That's good to know glad it's getting fixed!
Now reward us with some damn vids lol!!
05-04-2013, 07:22 PM | #10 |
Drives: Florida Speed & Power Join Date: Jan 2011
I was gonna say Driveshaft or that godforsaken Heat shield in the tunnel. Mine came loose and was vibrating against the exhaust and drove me NUTS! Glad you guys figured it out! Now like litle88 said, VIDEO!
05-04-2013, 08:07 PM | #11 |
Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
05-04-2013, 08:15 PM | #12 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
^ Litle has become the forum psychic mechanic.
05-04-2013, 08:50 PM | #13 |
Drives: 2019 F150 RCSB Abyss FX4 Join Date: Aug 2009
Video sounds awesome!! Which cam did you get?
05-04-2013, 08:57 PM | #14 |
Its a "Comp Cam 231/247" i can post full specs later since i don't have that on hand and thanks!
