03-22-2018, 12:42 PM | #1 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
L99 Timing Chan Tensioner Broken
So during my heads, cam, etc., install, a timing chain tensioner was found broken at just 33k miles.
What is the fix for a bullet proof setup? Will this work? http://www.jegs.com/i/Cloyes/220/9-3673TX3Z/10002/-1
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
03-22-2018, 12:54 PM | #2 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
What i did as well as many others on here is to swap it with an ls2 dampener. The link you have is for a whole timing chain set but the tensioner pictured is the ls2 dampener. Unless you need the whole kit then you could just buy the dampener by itself and it’ll be much cheaper.
03-22-2018, 12:55 PM | #3 |
Drives: LSx Powered Join Date: Oct 2009
https://www.briantooleyracing.com/ch...-12588670.html We upgrade all Camaro's to the LS7 solid tensioner to alleviate that issue. |
03-22-2018, 02:12 PM | #4 |
'It's an experiment'
LS2 or LS7 damper is the ticket!
LS7 version: 32k at the time, mine was still ok.. -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 03-22-2018 at 02:26 PM. |
03-22-2018, 02:17 PM | #5 |
Drives: 13' 1LE Join Date: Apr 2012
Mine broke at 20k
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
03-22-2018, 02:46 PM | #6 |
Mine was broke at 65k.
03-22-2018, 02:51 PM | #7 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
Any tell tale signs prior to pulling the timing cover? Can you hear the chain rattle or anything before complete failure?
03-22-2018, 04:35 PM | #8 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
what is the difference between the 2 other than the color? is there one? tks!
03-22-2018, 05:05 PM | #9 |
From what I was told, this is the GM ‘performance’ damper/number and is made to withstand more timing chain slap/performance use. Could be different material than the LS2 version (looked like it).
That’s all I was able to find out about it... -Don
747 RWHP 794 RWTQ
03-22-2018, 05:16 PM | #10 |
Drives: 2010 SS Join Date: Jun 2015
Mine was good till 120k then i money shifted it and well a few things broke lol
03-22-2018, 05:34 PM | #11 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
03-23-2018, 08:10 AM | #12 |
LSx FTW!!!
Got the LS2/LS7 damper.
Should I atleast upgrade the stock timing chain, too?
03-23-2018, 08:44 AM | #13 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
C5R chain would be a good upgrade/replacement
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-23-2018, 09:23 AM | #14 |
I had no idea mine was broke.
Thread Tools | |
