JUICEDMOTORSPORTS
Old 02-28-2011, 05:22 PM   #1
ColdCamaroSS
ColdCamaroSS's Avatar
Drives: 1
New Holley LS3 cast intake manifold
http://www.holley.com/300-116.asp
Looks pretty cool and although no prices have been announced yet, I've been reading under $650 bucks with fuel rails.
Any chance it would fit under the stock hood?
ColdCamaroSS is offline   Reply With Quote
Old 02-28-2011, 08:39 PM   #2
SC2150
This one will fit under the stock hood:
Old 02-28-2011, 08:40 PM   #3
redsap05
Drives: 2005 pontiac gto
I am sure this will go down the same path the weiand intake went down.
redsap05 is offline   Reply With Quote
Old 02-28-2011, 08:44 PM   #4
thesnoopster
thesnoopster's Avatar
Drives: '10 SIM SS/A6 - '12 SIM Equinox LT
I think the Holley intake wont fit under the stock hood...... I could be wrong on that though
SC2150 thats a nice piece! .... but probably beyond my $$ range :(
2010 SIM Camaro 1SS/A6
Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone"
Old 02-28-2011, 08:49 PM   #5
SC2150
Redsap05, I totally agree. The weiand actually LOST power over the LS6 when hot.
Snoop, yes it's pricey. Made by John Beck to fit our 115mm TB and fit under stock hoods. Here is the standard height:
Old 02-28-2011, 10:23 PM   #6
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
+2
They will also suffer from a lot more heat soak than a plastic manifold which robs power.
I guess we will see.
Black 2016 1SS A8 NPP
Drag Pack, CAI, Headers, Mamo Ported MSD Intake, Pray Ported TB, Shrader RSD, E85
Best ET- 10.85 Best Trap- 126.55
490RWHP/487RWTQ
ULTRAZLS1 is online now   Reply With Quote
Old 03-01-2011, 08:18 AM   #7
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
I don't even need to click on the link to know what manifold this thread is talking about.
and IT IS SEX!
it's a really nice design. Blows the doors off of anything else in the market at the moment imho, besides sheetmetal intakes and the cary intake (both are well into the 4 digit range).
It isn't out to the public yet (I believe VA speed has a few of the protypes at their shop right now), but it would be worth getting a cowl hood for. lol.
different tops:
Dual 4150s
DUAL 4500s!!!!!
danhr is offline   Reply With Quote
Old 03-01-2011, 08:28 AM   #8
mtbikerinme83
mtbikerinme83's Avatar
Drives: IMB 2SS/LS3-M6
The unit Holley made for the ls1 lost power compaired to stock due to heat soaking.
IBM 2SS LS3-M6
CAI intake with JRE race scoop, VMax TB, Solo HF Catted Mid pipes, and JRE SCT tune
mtbikerinme83 is offline   Reply With Quote
Old 03-01-2011, 08:43 AM   #9
danhr
BAMF SS
danhr's Avatar
good thing the 5th gen doesn't have an ls1, nor is the design for the modular intake anything remotely close to the street warrior intake.
Old 03-01-2011, 10:48 AM   #10
ULTRAZLS1
ULTRAZLS1's Avatar
I didnt even look at the link...I figured it was just a metal version of the LS3 manifold like the weiand was on the ls1.
This might be something to look at.
490RWHP/487RWTQ
Old 03-01-2011, 11:25 AM   #11
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
One of these intakes might make it onto my third gen when the 370 is built. It doesn't run long enough to worry about heatsoak.
Ucantctchme is offline   Reply With Quote
Old 03-01-2011, 11:26 AM   #12
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Will this intake be made to make power on a stock short block with just cam and bolt-ons or would it need a stroker/high compression race build to work?
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-01-2011, 11:31 AM   #13
danhr
BAMF SS
danhr's Avatar
the intake with the top from the very top picture would be more suited for a cam setup, but would really shine in a greater than stock displacement motor or possibly a max effort cam only setup. Probably wouldn't make very much more power on a bolt on setup
The other two tops are pretty much for a drag race only application, as it would require ditching the factory pcm for an aftermarket one, because currently there are no drive-by-wire 4150/4500 throttle bodies.
That and if you have the need for two 4150's, let alone two 4500's, you aren't driving that thing on the street anyways. lol.
Old 03-01-2011, 11:33 AM   #14
ballistic
LS1 to a LS2 to a LS3
ballistic's Avatar
Drives: 2011 Camaro 2SS/RS IBM
Installation Notes
These parts should be used for the following applications: Racing/Performance/Street Rodder where hood restrictions are NOT a consideration. Top can be mounted forward or backward.
ballistic is offline   Reply With Quote
WTB: LS3 intake manifold with fuel rails and injectors G_Loc V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 6 10-13-2010 08:21 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 01:04 PM
