09-20-2017, 04:16 PM | #1 |
GAHDOOSH
Drives: 2016 Camaro 1SS Join Date: Apr 2013
Hard wiring radar detector to pass. footwell
Spent hours removing the passenger footwell insulator and glove box to find a bunch of harnesses. No easy labeled accessory wire or ground wire. Thought someone doing footwell lighting would have figured this out already but a google search provided only plug and play GM footwell lighting kit install instructions. Anyone got a photo of which one of those wires to tap into? 2016 1SS
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning |
09-20-2017, 04:27 PM | #2 |
Drives: 2017 Camaro 2SS Join Date: Feb 2017
well the the area above the mirror is the easiest place to hit if you are just doing a radar
09-20-2017, 04:42 PM | #3 |
Drives: 2016 Camaro SS, Garnet Red Join Date: May 2013
Yes, the overhead console is easier to access the wiring. See http://www.camaro6.com/forums/showth...ighlight=radar
Or you could buy a plug and play harness http://www.gen5diy.com/Chevrolet/Cam...arness-220300/ |
09-20-2017, 08:26 PM | #4 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
Driver's side under dash where the wiring harnesses are is a easy to reach ground and power. I posted somewhere in here when I did my footwell lighting. But the overhead console is the easiest for radar.
09-20-2017, 10:39 PM | #5 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Run a hot wire from the trunk to the front of the dash...
That's what I did.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
09-21-2017, 12:34 PM | #6 |
Pizza & Wings Only $12.99
Drives: 2017 Camaro SS Join Date: Jan 2012
I can't help you with the wiring from a side panel.
But I can vouch for the plug and play harness from gen5diy. Took me 15 minutes maybe to install it and it was simple and straight forward. Completely reversible too if you want to remove it eventually.
H-Town Camaro Club
Past Rides: 2012 Camaro 2SS/RS M6 2012 Camaro ZL1 A6 2017 Camaro 2SS M6 |
Tags |
accessory, radar, wiring, wiring help |
