10-27-2017, 08:08 PM | #1 |
Drives: 2018 ZL1 Join Date: Nov 2013
Get your lugs checked !!
I have been reading on some of the ZL1 Facebook pages that the lugs on the car may be loose from the factory. I have a track day coming up so I decided to swing by Discount Tire on the way home since I got off early. Low and behold 15 of the 20 lugs on the car were loose !! Now its not like the wheels were going to fall off but only my front right wheels had fully tightened lugs. Im glad I swung by.
Just wanted to mention it to everyone. Have a great weekend |
10-27-2017, 09:16 PM | #2 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Good advice. I ended up with the clicking sound coming from the left front wheel around 1000 miles in. I took the wheel off, cleaned the mating surfaces, and reinstalled. A few miles more, the clicking returned. This time I went to the right front since it sounded like that's where it was coming from. Problem fixed once again. Then around the 4000 mile mark it seemed like I was getting the clicking again, but it was harder to hear. This time I grabbed my torque wrench and went to the rear wheels. They were both way under torqued. Almost loose even. So it's possible the fronts didn't really need to be taken off and cleaned, and just a simple retorque of the lug nuts may have solved the clicking.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
10-28-2017, 12:31 AM | #3 |
Drives: 2018 ZL1 A10, 2019 BMW X5 Join Date: Dec 2016
What's the correct torque specs for the lugs?
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017 |
10-28-2017, 01:29 AM | #4 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
140#
10-28-2017, 05:47 AM | #5 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
If you're going to be doing track days, my suggestion would be to buy your own torque wrench, and then you can easily ensure that the lugs are torqued to 140 lb/ft before each event.
10-28-2017, 07:37 AM | #6 |
Drives: '21 ZLE A10 Join Date: May 2012
the dealer is supposed to check lug torque during PDI. All of the studs stretch just a little so, recheck the lug torque numerous times during a track day. Wait until the car has cooled a bit before checking the torque.
10-28-2017, 11:31 AM | #7 |
Thanks, I'm going to stop by the tire shop today and have them check mine...JUST to be sure!
10-28-2017, 02:56 PM | #8 |
I love crepes
This is a must. Those are going to loosen up as you spend time on the track and you're going to want to check them frequently. Do yourself a favor and put together a small plastic container with a "track kit" if you're going to track more than once.
10-28-2017, 09:15 PM | #9 |
Got them checked...basically no movement on any of them. All at 140#. I feel better!
10-29-2017, 12:27 AM | #10 |
I was a little surpised to see that he got movement on most , but some almost 3/4 turn!
10-29-2017, 12:30 AM | #11 | |
will do. What was surprising was how loose they were before the car even saw a single lap. |
