07-20-2018, 11:01 AM | #1 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
AGP 6868's FINALLY switched to E ,DYNO RESULTS!
I finally jumped on the ethanol train and during tuning we made some 20 pound test hits. Car is at 60% duty cycle on the controller and this is through an unlocked converter on slicks.
This is about as high as I want to go with 4 bolt heads and I hope it lasts.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
07-20-2018, 11:05 AM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Niceeee
Sent from my SM-N950U using Tapatalk |
07-20-2018, 12:26 PM | #3 |
'It's an experiment'
Insane what our cars can do. Awesome results...
-Don
747 RWHP 794 RWTQ
07-20-2018, 02:12 PM | #4 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
That is awesome!! Do you have the modified AGP plenum or is the standard that comes with the kit?
E is awesome!!! Like I said make more power with less boost! Can't beat that!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
07-20-2018, 02:47 PM | #5 |
this is the 2" agp plenum. this winter I might change the cold side but its hard to justify with these kinds of numbers. Car ran a 9.91 at 13 PSI on race gas. We are hoping for some bottom nines soon
07-20-2018, 03:13 PM | #6 |
Drives: Z06 wannabe Join Date: Feb 2015
That is a BEAST
Apex Focused
07-20-2018, 05:23 PM | #7 |
Very nice man. Can't wait to see some great times at you da
Cai intake and a few other mods😎
07-21-2018, 07:03 AM | #8 | |
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
07-21-2018, 09:18 AM | #9 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Wooo sweet numbers should fly at the track!
07-21-2018, 12:03 PM | #10 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
this is amazing! congrats man! should be moving out
07-21-2018, 12:03 PM | #11 |
Nicely done and with slicks to, crazy. Get some track vids so we can see this thing eat the 1/4 mile!
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq |
07-21-2018, 02:53 PM | #12 |
Awesome!
07-21-2018, 03:58 PM | #13 |
Drives: Camaro Join Date: Aug 2015
What is the modified one you guys are talking about and what's the pros of it?
07-21-2018, 06:06 PM | #14 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
These versus the AGP plenum
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
