03-20-2014, 05:15 PM | #1 |
Drives: '14 1SS 1LE white Join Date: Nov 2013
Titanium lug nuts
Would anyone be interested in a group buy for these?
http://www.ozmoengineering.com/produ...tanium-lugnuts OZMO currently doesn't produce these in the 14 x 1.5 with a 60° seat necessary for our cars. They agreed to produce the forging tool needed to punch out these things if we can get a minimum of 10 preorders @ $159 for a set of 20. Let me now if there is interest! 1.) NJ Drive 2.) Christianmotox 3.) Zerort 4.) Synner 5.) ZL575BumbleBee 6.) Spartan01 7.) wwx8989 Last edited by NJ Drive; 04-30-2014 at 05:28 PM. |
03-20-2014, 05:18 PM | #2 |
Drives: '14 1LE Join Date: Nov 2013
Would these be primarily for track day?
03-20-2014, 05:28 PM | #3 |
With any open lug nut, you're prone to contamination if driven in foul weather. That said, I've run them for years with no problems at all, on the street and for autocross.
An OZMO rep has stated that they produce these as hobby at a low price point to support their race teams. |
03-20-2014, 05:43 PM | #4 |
Drives: cars Join Date: May 2011
Would they fit in wheels that require narrower than stock "tuner" lugs like forgestar CF5's? That may limit your interest pool.
03-20-2014, 05:48 PM | #5 |
Considering they'd require a 18mm or 19mm socket, I believe that these are pretty narrow.
03-20-2014, 06:21 PM | #6 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Nice!
Let me know when you get them so I can jack them from you
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
03-20-2014, 06:29 PM | #7 |
Drives: ( . )( . ) Join Date: Feb 2010
I'm down
03-20-2014, 07:13 PM | #8 |
03-20-2014, 07:23 PM | #9 |
03-20-2014, 07:26 PM | #10 |
I can pull and measure one of mine to see if it'd work once you hear back, gonna have the fronts off this weekend anyways.
Every time I've assumed based upon logic I end up wasting money as the world is illogical, or at least the people on it are. |
03-21-2014, 03:49 PM | #11 |
Drives: 2014 AGM Camaro 1LE, 2SS, RS 3/25 Join Date: Mar 2014
I'm in.
03-24-2014, 07:36 PM | #12 |
Bump, let's make this happen.
03-24-2014, 08:01 PM | #13 |
The latest bit of feedback from OZMO:
Hi David, When I design, I will check to ensure fitment of all Camaros including Z/28. After designing, I can advise the outer diameter of the 60deg. taper, and if there is fitment issues, I will guarantee refund. Ti lugnuts require a small amount of antiseize to prevent galling. As such, we always recommend a low seating-torque and then turns-of-the-nut method to match the stock nut clamping force. The on-torque with antiseize is typically around 30% lower to achieve the same clamping force. Unlike Aluminium lugnuts, Ti Lugnuts can hold the same clamping load as stock steel ones. Regards, Jamie |
03-24-2014, 08:23 PM | #14 |
If they wanna guarantee fitment then I'm in.
