O2 wire extensions and rear O2 bung extensions with long tubes ???
What length O2 wire Sensor Extensions are required when installing new long tube headers , is the "Trapezoid 4-Position 12" HIGH TEMPERATURE" the best for the front sensors ?
What about the rears, are they required there too ?? I going with a cat delete set up, will the O2 sensor bung extensions help to prevent throwing a code ? Will any of these work http://bigdaddiesgarage.com/ I'm guess in the rears might as well just be tuned out as I'll need a tune when I finish installing headers and a cam ![]() Thanks !!
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
#2 | |
BCS Auto
![]() ![]() Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
You do not need extensions for the rear. You WILL throw a code with long tube headers and no cats unless you get a tune. You are leaving approx. 20-25hp on the table by NOT getting a tune. Therefore, I highly recommend you get the car tuned.
ALSO, if you do get the car tuned, the rear O2 sensors get completely deactivated to the point that you don't even need to install them in your catless mids. You can simply install bung plugs instead. This is how I roll on mine...
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
![]() Drives: 2010 Camaro SS (LS3) Join Date: Dec 2015
holy shit, just checked the site and $50 is ridiculous.
I've done this on my old rsx-s, on my ex's prelude, and know plenty of people that have done it. but you dont need a specific overpriced part. they have it at autozone for like $8. |
