#Camaro6
Old 01-30-2020, 10:13 PM   #1
murdamaro
Drives: 2018 Camaro ZL1
ZL1 Leaking Oil From Front Main Seal With Stock Lower Pulley??
Okay guys new member here so dont roast me too hard lol
The other night I went for a pretty hard ride in my car, maybe like 4-5 hard hits. Parked the car in my buddies driveway and went inside for like 10 mins, when pulled off he texted me a picture of his driveway with oil on it that leaked from my car. I pulled over immediately and checked the dipstick, just a little shy of full maybe like a third of a quart. So I finish my drive, put the car in my driveway, slid a piece of cardboard under it and went to sleep (by this time it was 3am and I was out on the boat allllll day, beyond tired) wake up at like 7am and had to go check it out. A little oil was on the cardboard but not nearly as much as my buddies driveway so I feel like it was residual just dripping off the belly pan. Then I popped the hood and found oil on the front of the motor, top of the starter, and inside the lower pulley. My ramps are at my shop and unfortunately I have been stuck in bed since this with the flu, ill pull the belly pan this weekend and confirm that its not the oil pan, but im kinda guessing at a front main seal that leaks mostly when under power? Car has 11,000 miles on it and really doesn't get abused that often, kind of crazy to think the front main would leak without ever pulling the lower off and exposing it to possible damage. I did some thread research and really only found this issue on SS cars with blowers, any info or guidance will be much appreciated!!
murdamaro is offline   Reply With Quote
Old 01-30-2020, 10:48 PM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Ya, its happened to many of us. Replace it with an LS3 seal and you'll be good to go
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 01-31-2020, 05:47 AM   #3
murdamaro
Why did it blow out tho? I am running the factory pcv system, should I upgrade that as well? or is crank case pressure not the culprit here?
Old 01-31-2020, 06:25 AM   #4
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
Wouldn't hurt to run a MM catch can good insurance in my opinion. I'm running 2 and venting the oem. Your intake valves and crank seal will thank you!
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 01-31-2020, 07:51 AM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I know alot of us boosted LT1 guys have, but have the ZL1s had this problem too?
TheRealJA105 is offline   Reply With Quote
Old 01-31-2020, 08:13 AM   #6
Krowser
Krowser's Avatar
Drives: ZL1 Mosaic Black
What oil weight are you using?
If you were doing freeway pulls with 5W 30, your asking for trouble due to 30W being too thin for prolonged track type driving.
I hope you are using 0w 40 or 50W.
Anyway, take it into the dealer.
Krowser is offline   Reply With Quote
Old 01-31-2020, 08:47 AM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
+1 LS3 seal and a catch can. We sell the Elite Engineering catch cans. Grab the E2X from us with code CAMARO6. That will take care of your issue.
Juiced1 is offline   Reply With Quote
Old 01-31-2020, 08:52 AM   #8
FoundNemo
Drives: 2019 ZL1
If its under warranty, just take it in and make them fix it.
FoundNemo is offline   Reply With Quote
Old 01-31-2020, 09:29 AM   #9
Krowser
Krowser's Avatar
Are you saying replace the stock oil pump seal with an LS3 gasket or an LS3 oil pan gasket?
Old 01-31-2020, 09:41 AM   #10
TheRealJA105
Drives: 2013 C6Z06
Front main seal LS3
Old 01-31-2020, 10:38 AM   #11
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
This is an issue with ZL1's as well?
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 01-31-2020, 11:40 AM   #12
murdamaro
No warranty, car is obviously tuned with bolt ons. I don’t mind replacing it myself I just want to know if I’m the only ZL1 with a factory lower that has dealt with a leaking front Main.
Old 01-31-2020, 11:41 AM   #13
murdamaro
That’s what I’m trying to figure out also, is yours leaking?
Old 01-31-2020, 11:42 AM   #14
murdamaro
No warranty, car is tuned with bolt ons.
2018, front main seal, oil leak, zl1
