Old 03-02-2012, 09:17 PM   #1
Camaro45thAE
Camaro45thAE's Avatar
Drives: '91 GMC Syclone & '12 Camaro 45TH
CEL - Reduced Engine Power?
While going out to the Sunshine Rally today, I had just come off the highway and was sitting idle in 1st gear waiting to turn when suddenly the car stumbled and I get CEL with Reduced Engine Power warning on the DIC. All the traction lights came on too.
I had to go through the intersection, and the car did cough and stumble when I started to roll out...and then came back enough for me to get it safely into a parking lot.
Turned it off, popped the hood and checked underneath for any fluids dumping...everything seemed normal. Turned it back on and still had the CEL light on, but the reduced engine power notice was gone. Car seemed to drive normal again. Got to the hotel and hung out for a bit. Still had the CEL and no warning on the drive home and car acted normal (good 45 mile drive). No weird sounds the entire time.
Im going to the dealer first thing in the morning, but anyone else seen this type of issue...especially on a 2012 yet?
2012 2LT M6 with 4600 miles on it.
adam
GMC Syclone #237
2012 Camaro 2LT Anniversary Edition
Order No. PTXV9B
8.31.2011 - Born! TPW 8/29
HowTune- DIY Automotive Network
Camaro45thAE is offline   Reply With Quote
Old 03-02-2012, 11:35 PM   #2
nukemustang
nukemustang's Avatar
Drives: 2017 Raptor, 2017 SS
easy way would be to stop at an auto parts store, most of them have code readers you can borrow for free and you can google the code pretty quickly. I had some problems with another vehicle, so i ended up purchasing a code reader, makes checking and clearing CELs quick and not dependent on auto parts store hours... hope this helps.
Saving for: 2019 ZL1 convertible.....
SOLD:2016 2SS Red Hot Convertible with black metallic rally stripes
SOLD:2011 Silver Ice Metallic 1SS/RS Convertible. Completed modifications: installed factory HUD, deleted AFM/DOD, Dynatech LT coated headers with high flow cats, Solo Cat back exhaust, CAI inc. intake, Vmax ported TB, SIM quarter flares/splash guards, steering wheel radio controls, PDIM iPod interface in center console, RX catch can, JRE cold air scoop, windshield washer bottle relocation.
nukemustang is offline   Reply With Quote
Old 03-03-2012, 02:44 AM   #3
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
sounds like it went into limp mode for some reason. could have been from a misfire. limp mode is when the car goes into a reduced power mode so that you don't further ruin the engine. as stated above, you can go to an autozone and borrow theirs, and/or buy your own for about $50 so you have it with you at all times, and can check it.
But yeah, new car and i'm assuming no mods, it's best to just take it to the dealer.
Old 03-03-2012, 07:05 AM   #4
Camaro45thAE
Just got word: fuel rail sender causing the prob. Part is being ordered and will be replaced (not today).
adam
GMC Syclone #237
Order No. PTXV9B
Old 03-03-2012, 05:11 PM   #5
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
I had that happen to me , It seems if you shift into a wrong gear by mistake the computer takes over and reduces the eng. Pwr. I was on my way home when that happened to me, the car was running so bad and so slow, I didn' think I would make it to the Gm dealer, but after about 5 mins, the car started to run normal and the eng warning lights went out.
gutterball is offline   Reply With Quote
Old 07-20-2012, 07:54 AM   #6
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
This happened to me twice and I have an automatic. Happened when I stopped at a light two nights ago. Started back up after a few minutes. Then it happened this morning while pulling up to park. I'm going to take her into the dealer....I had tirekingdom change my oil last night and asked what code it pulls on the history. I can't remember if he said p206 or p406...but he said blip in computer. Don't know what that means but I hope its something simple. I'm worried it might cut off when I'm driving on the expressway!
I think the code was P1406 EGR Pintle Position Error
P1406 Exhaust Gas Recirculation System Pintle Position Error ..not 406.
I hope its gas!!! lol
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 01-04-2013, 07:34 PM   #7
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Reduced Engine Power warning on the DIC of 2010 SS Camaro
My SS has done this 3 times now. Went to the dealer the first time and they said they re calibrated the injection system. The second and 3rd time I pulled the front engine compartment "jumper" bolt and cable for a few minutes....re installed it and it fires right up as normal. The CEL stays on for a few more minutes but then goes away.
So today I go to the dealer and I told them I remove the front jumper bolt and they said I can cause more problems and maybe blow some other modules by doing that! I think they are full of shit! If you can jump a car from that bolt....you are definitely not going to hurt anything else. AM I WRONG in that assumption anyone?
God is too good! I don't deserve it, but I sure will accept it!
ZX1truth is offline   Reply With Quote
Old 01-04-2013, 08:56 PM   #8
Chevy Fanatic
Drives: 2011 2SS/RS IOM/PEARL STRIPES-6M
You are disconnecting and reconnecting a +12 volt cable. I would not recommend doing this. It can spike one of the computers unless you remove the neg cable first. Never remove/install a pos cable without first removing the neg cable.
Chevy Fanatic is offline   Reply With Quote
Old 01-05-2013, 02:11 PM   #9
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
If your battery goes dead....and you then jump it from this terminal from another car or a 50 amp car charger...how does that not fry the computers/modules but just taking the + cable on and off does?????? That doesn't make sense to me.
Old 01-05-2013, 02:38 PM   #10
Chevy Fanatic
As stated NEVER remove a +12 volt cable without removing the neg cable first. This is true also when jumpstarting a vehicle. When connecting a battery ALWAYS connect the pos cable first, then the neg. Same for jumpstarting. Pos cable first, then neg cable. When disconnecting, it is reverse order, neg cable first, then pos. Also I did not indicate you would fry the computer as you stated. I said you COULD spike the computer.
It appears you do not have a clear understanding of what happens when you connect/disconnect cables in the wrong order so let me see if this clears up your confusion. If you hook up your battery by putting on the pos cable last you will get a spark/arc. Apply the pos cable first then the neg, no spark. Spark/arc is not good on the vehicle electrical system/ computers.
Old 01-05-2013, 02:46 PM   #11
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
As stated NEVER remove a +12 volt cable without removing the neg cable first. This is true also when jumpstarting a vehicle. When connecting a battery ALWAYS connect the pos cable first, then the neg. Same for jumpstarting. Pos cable first, then neg cable. When disconnecting, it is reverse order, neg cable first, then pos. Also I did not indicate you would fry the computer as you stated. I sais you COULD spike the computer.
Geeeez....relax pal! Just asking a question. Thanks for the input.
Old 01-05-2013, 06:28 PM   #12
Chevy Fanatic
Relax? I think you misunderstand my post. I am simply trying to help you understand the issue.
Old 10-02-2015, 08:53 PM   #13
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
I'm going to revive this post. I have had the reduced engine power light go on. Took it to the dealer. I was told I had a lot of carbon built up from my cold air inductions intake. The dealer cleaned it all off, everything was fine.
I ordered a new air filter for it but right before I got the new one it has happened again. Do you think I'm the few miles (less than 100 miles) I drove with the dirty air filter this could have happened again?
Haole is offline   Reply With Quote
Old 10-02-2015, 09:43 PM   #14
CRF8
Space Coast Camaro's
CRF8's Avatar
Drives: 2017 Camaro SS / 1974 Firebird 400
No
CRF: Sent from my iPhone using Tapatalk
Hyper Blue 2017 Camaro 2SS, MRC, dual mode exhaust, window tint
SOLD: 2014 Camaro 2-SS red rock metallic,
named "Waste of Money" by the wife,
RS package, 93 tune, front strut brace, window tint, Lloyd's trunk mat, cargo net & organizer, LED blue dome & trunk, BMC fade gills, RotoFab CAI, Granatelli axle back, Gorilla wheel locks, Expel headlight protectors,V-max throttle body.
http://spacecoastcamaros.com/scc/index.php
CRF8 is offline   Reply With Quote
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 03:46 PM
engine power is reduced??? sswish 5th Gen Camaro SS LS LT General Discussions 9 10-22-2010 04:52 AM
Mustangs................ vontivonti 5th Gen Camaro SS LS LT General Discussions 4052 12-21-2009 10:42 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 07:37 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
