Jason 98 TA
Old 10-19-2018, 09:40 PM   #1
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
Tune out decel pop
I have an NPP exhaust with the fuse pulled, really like the sound other than the crackling on deceleration.
What should a tuning shop charge for just that change in the computer?
Hopefully I can find a place that will do that 1 change...
Thanks!
Quicksilver2SS is offline   Reply With Quote
Old 10-22-2018, 12:21 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Thanks!
You really would not want to go through the process of tuning and not take full advantage of all the benefits of a full custom tune.
Purchase an SCT X4 tuner from me and get your first full custom tune FREE.
Then you will be on our buy parts from me get tune updates for free program.
https://jannettyracing.com/products/...x4-power-flash
Ted.
www.jannettyracing.com
Celebrating 33 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-22-2018, 01:28 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2013 Camaro LSX427 TT
Here's a screen shot from HPTuners of the fix for me. I disabled DFCO (decel fuel cut-off) by making the Enable ECT (engine coolant temperature) 414*F (so it doesn't happen). The default is 14*F. Like Ted said, it's not worth having a shop just change that - it literally takes a few seconds to make the change and about 45 seconds to flash the ECU.
There can be other factors like adaptive idle coastdown timing and timing, but this is the first and easiest approach to tackling the decel popping.
xWHP / xWTQ at xpsi on E85 xsec@xmph DA ft at xpsi boost TBD
LSX427 | AGP 65/65 TT | BTR Equalzer Intake | Trickflow 245cc cathedral | BTR custom cam | AEM TruBoost | n2mb WOT | ID-1700x | NGK BR7EF | DSX Flex Fuel Sensor | AGP's Fore Triple Fuel | Monster LT1-S Triple | 3.25 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 10-22-2018, 01:47 PM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
Thanks!
All you gotta do is change the DFCO timing to make the pops softer. If you know someone with hp tuners they could do it for ya quickly. It's two tables that need changing
Doubt a shop would charge much to make this change. I wouldn't advise disabling it as it'll impact mpg's
2010 2SS/RS
Z/28 intake, ported TB, vr wedge, rod-mod intake, speed engineering LT's, NPP catback, ATI -10% pulley, MGW shifter, 160* t-stat, HP Tuners, some suspension work, stickers and a little weight loss. 12.72 @112.36 - improvements coming
xc_SS/RS is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
