Old 11-04-2018, 11:38 PM   #1
BAH2SS
Stigs Bahraini Cousin
BAH2SS's Avatar
Drives: 2015 Camaro 2SS 1LE
Driver side door trim scratch
I have accidentally scratched the door cover/panel on the driver side. is there anyway to repair the scratch or make it less obvious? This is just my second week owning the car
Attached 2 photos of the scratch
2015 CAMARO 1LE
https://www.camaro5.com/forums/image.php?u=143224&type=sigpic&dateline=1541618573
BAH2SS is offline   Reply With Quote
Old 11-05-2018, 02:00 AM   #2
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
wtf did you do to it? You'd have to get a new door card
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 11-05-2018, 09:57 AM   #3
paulsandhu
paulsandhu's Avatar
Drives: 2010 Camaro 2SS/RS
Let me guess, opened the car door with the key extended?
Sorry pal, the only thing you can do is replace the parts.
GHOST · 2SSRS
Order Date: March 28, 2009 // DoB: June 19, 2009 // Arrival Date: July 2, 2009
Current Modifications:
  • Hurst Comp HardDrive Stick Kit
  • K&N Blackhawk CAI
  • Anvil Carbon Fiber Notch Spoiler
  • Ceramic Coated Satin Black Wrap
paulsandhu is offline   Reply With Quote
Old 11-05-2018, 10:14 AM   #4
BAH2SS
BAH2SS's Avatar
No, i had a hand rest there and pulled it back so the bottom part of it scratched the panel. I found a shop here that can fix it. I will update this post of this scratch is fixable.
2015 CAMARO 1LE
Old 11-05-2018, 11:09 AM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Interested in procedure and results as I’ve got a rub mark from something? T that removed some of the finish on the panel.
camguynj is offline   Reply With Quote
Old 11-05-2018, 12:07 PM   #6
BAH2SS
BAH2SS's Avatar
If i am not mistaken, the shop will sand the plastic, polish it and then apply a clear coat over it. I will ask them though on what they did to repair it once they are done from it.
2015 CAMARO 1LE
Old 11-05-2018, 04:09 PM   #7
1LEJNG
Drives: Red Hot 2014 1LE
scratch
what is a hand rest?
1LEJNG is offline   Reply With Quote
Old 11-05-2018, 04:38 PM   #8
BAH2SS
BAH2SS's Avatar
It's something locally made that you put on the door to use as a hand rest and has storage space. I threw it away
2015 CAMARO 1LE
Old 11-12-2018, 12:08 PM   #9
BAH2SS
BAH2SS's Avatar
So i got the scratch fixed. It was a very deep one too.
They wet sanded the scratch and polished it once the scratch was gone.
2015 CAMARO 1LE
Old 11-12-2018, 02:11 PM   #10
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Pics of the fix?
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 11-13-2018, 04:28 AM   #11
BAH2SS
BAH2SS's Avatar
I attached a photogl after the repair.
Note: the black plastic door trim had another procedure to repair which involves painting.
2015 CAMARO 1LE
