05-01-2023, 02:14 PM | #1 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
Amco shift knob and Z28 boot in an auto transmission
Hello, I am just wrapping up a project and figured I'd share it with y'all to maybe help inspire someone or at least just brag about a job well done.
It all started with a kit from White Madness Garage (WMG), which came with an M12 thread, but while looking at shifter knobs I found a 70s Amco Camaro knob and knew I had to have it. One trip to McMasters later I found the perfect thread adapter, biggest issue was the length, but since it's an auto I am not too worried about not having the slickest short shifter in town. With all that together I got working on having a set orientation for the shift knob, I tried jam nuts but both the WMG kit and the adapter had a large unthreaded areas on the male side so it was extending the size just slightly too far, loctite and glue were out of the question because disassembly of the trim was a pain without disassembling the stick, so what I did was 3D print a bunch of .2mm washers and kept adding them until that shiny Camaro logo was pointing forward, then I took the count and printed a single spacer. At that point I decided I wanted a fancy shift boot to match, I saw a thread here about fitting the leather one but figured now is my chance to add some suede to the car so I settled with the z28 one. Issue with the z28 shifter is the little plastic bit on top, and yes I could just remove the piece then tuck and zip tie suede bit but I got a little fancy and modeled\printed a cap that locks in to the boot cap and also acts as the spacer I designed earlier. This was the most time consuming one, biggest issue is that if it sat too high the boot was stretched to point where the car refused to let you take the key out because even in park it though car was in gear, but if you put it too low then you couldn't push down far enough to change gears (if anyone is interested in this piece I can upload the file somewhere, haven't done it yet because it feels super specific). Then presto, we got us a fancy shifter, I did experiment with some polyurethane clearcoat on the knob to protect the shiny highlights on image but it just flaked off (which is for better it looked awful). I will post some pictures below to show it off.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
05-01-2023, 02:18 PM | #2 |
Here is the picture of the first adapter, thought idea of shift pattern on it was neat but the writing ended up looking tacky and the gloss finish was pretty awful too, so I was lucky it wouldn't let the car function in that form so I had to redo it for something matt balck instead
05-12-2023, 07:28 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Looks pretty good!!
Orange Krush II
05-12-2023, 11:50 PM | #4 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
Looks cool
