#Camaro6
BeckyD @ James Martin Chevy
Old 10-31-2017, 12:55 AM   #1
Tran
Administrator
Tran's Avatar
Cool CHEVROLET CAMARO SS TRANS AM TA4-SPEC RACE CAR
TODD NAPIERALSKI’S CAMARO RUNS AT THE FRONT OF THE FIELD WITH CHEVROLET PERFORMANCE ZL1 1LE PARTS
2017-10-30
For more than 50 years, SCCA Trans Am has pitted production-based race cars in one of motorsports’ most exciting and enduring road-racing series. One of the standout competitors today is Todd Napieralski, who drives this Camaro SS racecar in the Trans Am TA4 class. He drove it to a second-place finish at Road America last year, in its first outing.
Part of Napieralski’s competitive edge with the Camaro comes from ZL1 1LE chassis and suspension components that enhance the car’s road-holding and handling capabilities. When built last year with the cooperation of Chevrolet Performance and Total Performance Racing, the ZL1 1LE components were mostly concept parts, but they have been incorporated in the production Camaro ZL1 1LE and many are available for purchase from Chevrolet Performance. That means any racer with a Gen Six Camaro SS can use them to build a more competitive racecar.
CAMARO SS PRODUCTION COMPONENTS
LT1 6.2L V-8 engine
Six-speed manual transmission
Brembo performance brakes
Limited-slip differential
CHEVROLET PERFORMANCE PARTS
  • ZL1 1LE-Spec Multimatic DSSV® Lowering and Handling Suspension Upgrade System (P/N 84352121) — Forged on the track and developed for the track-capable ZL1 1LE, this suspension system features Multimatic DSSV® dampers, combined with front and rear coil springs, and a ZL1 1LE-spec front sway bar. Ride height is reduced by up to 10mm and the system offers a 22 percent decrease in roll gradient, as well as a 245 percent increase in front spring stiffness. The front ride height is also adjustable for corner weighting and track use, with the ability to quickly switch from street to track camber settings.
  • ZL1 1LE-Spec Suspension Upgrade System (P/N 84352119) — This kit complements the ZL1 1LE-Spec Multimatic Lowering and Handling Suspension Upgrade System (P/N 84352121). This off-road-only, track-tested system offers racers front ride links, front handling links, rear upper and lower trailing links and rear knuckles, as well as stiffer bushings and ball joints to reduce suspension flex. Compared to the Camaro SS, the upper and lower trailing links are 71 percent stiffer, while the rear link inner bushings are 58 percent stiffer. There’s also a 4 percent reduction in roll gradient in addition to 1LE Spec Multimatic Lowering and Handling Suspension Upgrade System enhancement.
  • ZL1-spec solid-mounted rear cradle mounts — These mounts help reduce deflection in the rear suspension, for enhanced stability and more direct handling.
  • ZL1 rear spoiler — This aggressive ZL1-style spoiler kit can reduce vehicle lift on the track for Camaro LS, LT and SS models when used with the Camaro SS accessory ground effects or front splitter package.
ZL1 1LE CONCEPT PARTS
  • ZL1 1LE front fascia and front fenders
  • ZL1 1LE grille
  • Front splitter and dive planes
  • ZL1 extractor hood
The Camaro TA4-Spec race car joins approximately 20 additional Chevrolet models this week at the SEMA Show, Oct. 31-Nov. 3.
Old 10-31-2017, 06:02 AM   #2
motorhead
A little confused by the article. So the car in the picture(the race car) is a standard SS with ZL1 body parts and 1LE underpinnings?
Old 10-31-2017, 06:22 AM   #3
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Sweet! I wonder how the first part number alone (shocks, springs, swaybar) on a regular SS compares to a SS 1LE.
Anticipating this package is one of the reasons I got the non-MRC suspension.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
vtirocz is offline   Reply With Quote
Old 10-31-2017, 06:34 AM   #4
kingbambino22
kingbambino22's Avatar
Drives: 2023Porsche Cayenne S
Pretty much a ZL1 1LE minus the LT4 engine. The car I was asking for. Now time for the "street legal" version. This car is going to be fast around the tracks.
kingbambino22 is offline   Reply With Quote
Old 10-31-2017, 06:39 AM   #5
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
I tried those part numbers @ thatgmpartsguy.com and they bring back "No results".
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 10-31-2017, 06:43 AM   #6
motorhead
so they are making this a production car? What makes a ZL1 a ZL1 if it doesn't have the LT4 seeing that the suspension is now 1LE? Forgive me just trying to understand.
Old 10-31-2017, 06:53 AM   #7
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
It could start as a production car or a body in white. Not sure what the Trans Am rules are. Either way it's turned into a race car homologated to run the TA4 spec class in the Trans Am Series. Much the same way The Pratt & Miller GT4 spec Camaros were built to race in IMSA and PWC. It will not be produced on the production line for sale to the masses.
Old 10-31-2017, 07:21 AM   #8
motorhead
Okay, thanks. That makes sense
Old 10-31-2017, 07:25 AM   #9
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
This is an example of what parts you can buy from Chevrolet Performance. It won't be a production car as-is.
Still....pretty cool!
Old 10-31-2017, 08:21 AM   #10
gpskinzhut
gpskinzhut's Avatar
Drives: 2017 ZL1 A10
Glad I wasn't the only one with that line of thought. Was hoping there'd be a DSSV suspension kit like the Z28 kit for the 5th gens.
Kinda seems like this would fit the Z28's M.O. eh? ZL1 1LE underpinnings but naturally aspirated?
2017 ZL1 A10
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 10-31-2017, 09:30 AM   #11
slick3
Drives: Garnet Red - 20 ZLE
Finally... we will forsure be seeing all the ZL1 1LE goodies trickle down to us peasants.
slick3 is offline   Reply With Quote
Old 11-03-2017, 02:02 PM   #12
kingbambino22
ZL1 1LE Spec Multimatic Lowering and Handling Suspension Upgrade System PART: 84352121 $5,995 MSRP
ZL1 1LE Spec Handling Component Suspension Upgrade System PART: 84352119 $1,195 MSRP
ZL1 1LE Spec Solid Rear Cradle Mounts PART: 84341929 $395 MSRP
ZL1 1LE Spec Adjustable Rear Stabilizer Bar PART: 84218218 $130 MSRP
6.2L Cold Air Intake System (50-State Legal) PART: 84329125 $525 MSRP
Front 6-Piston Brembo® Brake Upgrade System in Red PART: 23245471 $3,000 MSRP
Rear 4-Piston Brembo® Brake Calipers in Red PART: 84300395 $575 MSRP
6.2L Strut Tower Brace PART: 84125309 $195 MSRP
Old 11-03-2017, 02:41 PM   #13
gpskinzhut
gpskinzhut's Avatar
Time to sell a child.
2017 ZL1 A10
Old 11-06-2017, 11:16 AM   #14
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
Correct. Similar to the camaro GT4. They use the ZL1 bumpers for the added benefit of that wide open mouth for cooling and canards.
#53 F Street
2022 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
2022 Rapid Blue 1SS 1LE
2019 D Street national champion (2019 civic Type R)
apexit53 is online now   Reply With Quote
