Old 07-07-2012, 07:27 AM   #1
J666
Drives: Camaro
Rear Diffuser Faded
I washed my car today, and the rear was facing the sun. At first, I thought I didn't properly clean the diffuser, so I washed it again. After it dried up, it still looked like crap. I'm guessing the cheap plastic faded.
Would this be covered under warranty? Anyone else experience the same problem?
J666 is offline   Reply With Quote
Old 07-07-2012, 07:45 AM   #2
John Deere Boy
I bleed green
John Deere Boy's Avatar
Drives: '11 2SS/RS LS3
Black plastic always fades in the sun. Look at older Avalanches, Saturns, etc and you'll start noticing faded plastic everywhere. Armor-All will make it look better but of course it washes off and attracts dust. Mothers makes a product called "back to black" but it's not a permanent solution either. I doubt the dealer will warranty it since it's not a defect, but you can always try. I'm going to be upgrading to the 1LE quad diffuser as soon as i can get my hands on one.
2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen.
2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE
John Deere Boy is offline   Reply With Quote
Old 07-07-2012, 08:05 AM   #3
Cody6.2
Drives: 2012 Camaro 2SS
The biggest problem isn't actual fading but cleaners, waxes and so on ruining them. Obviously some people don't know better and wax plastic causing issues. But what most don't know is that even the wax stage at your local car wash will ruin plastic too.
Cody6.2 is offline   Reply With Quote
Old 07-07-2012, 10:26 AM   #4
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
Use Adam's Super VRT on the diffuser. I use it on black grills upfront, door trim, wheels, tires, the gutter under the windshield... the list goes on and on
Non-sticky and protects against UV and water; even hides water spots
edgehead2000 is offline   Reply With Quote
Old 07-07-2012, 10:32 AM   #5
White Shark
Drives: 2013 SS LS3
And mothers makes back to black, also is a cream that restores old plastic and works well on our diffuser. I might have to try Adam's, keep hearing good things about their products.
White Shark is offline   Reply With Quote
Old 07-07-2012, 11:03 AM   #6
mikeinmobile
mikeinmobile's Avatar
Drives: 2011 2ss/rs
This sounds crazy but it works wonders on all plastic or vinyl. Get a hand lotion with Lanolin and douse it down so that the lotion is still visibly white, let it soak 'till it's not immediately visible. Wipe down with clean towel. I discovered this helping a friend restore a 69 Chevelle. I was using hand cleaner (with Lanolin) to gently try and clean the vinyl arm rests and they looked pretty good (they looked trashed so I was experimenting). I took it a step further and doused 'em with hand lotion and a couple hours later they looked Year One new! They went from ready to crack to soft and supple. I used the same technique on several plastic pieces and got the same results. Now I use lotion on all my plastic/vinyl/rubber surfaces about once a year. Use unscented for interior. If you try it I'd be interested to hear your results.
mikeinmobile is offline   Reply With Quote
Old 07-07-2012, 11:04 AM   #7
Turbosaurus
Turbosaurus's Avatar
Drives: '14 Camaro 2SS/1LE
Yes, it it actual fading. I have an Avalanche and have never used cleaners, wax, or anything else on my plastic parts, and yet they are heavily oxidized. I have tried using mild abrasive pastes in very small spots to notice the effects, and while it removes some or most of the oxidation, it always returns.
Spoke to a well-respected body shop owner, and he said I should paint it, and gave me product numbers for Du-Pont primer and paint to use. If I find where I stashed the info, I will post it.
Past:
'69 Chevelle SS396
'79 Camaro 400SBC/TH400
Present:
'14 Camaro 2SS/1LE
'03 Avalanche (tow car for...)
Twin-turbo SBC Super Comp Dragster
Future:
FFR 33 Hot Rod w/ SBC
RCR GT-40 w/ LS7
Turbosaurus is offline   Reply With Quote
Old 07-07-2012, 11:09 AM   #8
MrGood
MrGood's Avatar
Drives: Broken palmghetto test car
Send a message via Yahoo to MrGood
Mothers back to black. Doesn't bend you over and works great.
MrGood is offline   Reply With Quote
Old 07-07-2012, 11:12 AM   #9
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I"ve heard of guys taking a heat gun or torch to the black plastics.
Personally I am not gonna try it but I've seen it done on YouTube.
It works really well. How it holds up after that I do not know.
Old 07-07-2012, 11:15 AM   #10
PQ
Booooosted.
PQ's Avatar
http://www.youtube.com/watch?feature...&v=2ue-1_Jk2Y0
Old 07-07-2012, 11:19 AM   #11
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
Dealer can warranty it.. They can spray a special protective coating on it. talk to your dealer. I use Back to Black..
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 07-07-2012, 11:22 AM   #12
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
back to black works great
Old 07-07-2012, 11:22 AM   #13
PQ
Booooosted.
PQ's Avatar
Or you can die it yourself. I've seen this done and, thought I wouldn't do it on interior that you see up close regularly, I'd do it on my rear diffuser.
Old 07-07-2012, 11:28 AM   #14
Grant
Grant's Avatar
Drives: 2013 2SS/RS AGM A6
Bobby Bolivia: "What with the semi-classic nature of the vehicle, slick wheels and custom paint job—"
Sam: "The paint's faded!"
Bobby: "Y-yeah, but it's custom."
Sam: "It's custom faded?"
Grant is offline   Reply With Quote
