04-17-2013, 08:40 AM | #1 |
Drives: 2010 SIM 2SS/RS Join Date: Jun 2009
How much hp can a stock driveline handle?
My car is at 592 rwhp and 552 to. I am about to add a cam and 3.91 gears, m6 car.
2010/SIM RS/SS LS3,M6, D-ISC PROCHARGER, KOOKS HEADERS,STOCK EXHAUST,NO CATS,MCLEOD RXT CLUTCH, 1400HP axles, ZLI FUEL PUMP,DRS. custom comp cam,gm 3.91 gears.651rwhp/568tq parts ordered, installled KyHorsepower.com,tuned by Bluecat
04-17-2013, 09:00 AM | #2 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
It all depends on how hard you drive it. I know that when I was at 684, I was concerned about my rear going boom, so at dead stops, I would ease into it, and after I was rolling, I got into it more. Since I've done my upgrade, I hit it a lot harder now. I would suggest that if you're going to change gears and you don't want a new diff., you should invest in caps, JRE posi mods, and maybe the LPW cover.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
04-17-2013, 03:39 PM | #3 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
With the right tire, launch rpm and traction I think the M6 cars have broken driveline parts at near stock power levels. At your power level I would seriously be looking at other options if you drag race on sticky tires.
04-17-2013, 04:23 PM | #4 |
Stroked and blown
I found this article to be pretty accurate. This question is usually answered with a lot of, would , should, might. Always nice and vague
http://www.hotrod.com/techarticles/g...e/viewall.html I have broken/replaced almost every part in my entire drive line. Axles usually go first
04-17-2013, 07:02 PM | #5 | |
That article is a good guideline to go by. Also try to take in to consideration that any part you upgrade, you could also sell the stock part to recoup some of your losses.
04-17-2013, 08:30 PM | #6 |
Drives: 2010 camaro Join Date: Aug 2009
blew out my slave cylinder at 660rwhp..they don,t seem to hold up well with hard launching..imo
04-18-2013, 05:38 AM | #7 |
Drives: own more cars than i can list Join Date: Nov 2010
like most are saying, with a manual trans the driver has allot to do with how parts will stay together. at your level i would suggest a few upgrades to make sure it stays together.
04-18-2013, 05:48 AM | #8 |
Thanks for all the input guys it is a m6 car. I do drag race 4 or 5 times a year , shooting for a 10 sec pass this year. I run low 11's now, with the cam and gears i hope i can get there. I am on stock suspension for now except for the 1400hp axles I already have.
04-18-2013, 07:11 AM | #9 |
hopefully, you don,t drive far to track and have a trailer if it go,s boom..
04-18-2013, 04:47 PM | #10 |
Stroked and blown
Big fan of DSS. Good stuff
04-18-2013, 09:46 PM | #11 |
Drives: 2SS/RS Join Date: Jul 2009
1100+ rwhp through stock driveline (besides the clutch) and still holding. At first it was a joke to see how long drive line will last but now I really am curious. I contribute the lasting effects to a great mechanic, CBI Streetcars and, fixing the problems with the car. It's obviously not power that kills the driveline as 426 FWHP has been enough to break them. I believe that weak or noise reducing parts of the suspension allow things to bind and/or create wheel hop which is a number one killer of any axle. Luckily BMR has many great things to offer to help the 5th gen track straight and true.
04-20-2013, 05:35 AM | #12 |
Great info, I am going to keep the stock driveline for now. Parts are in , drop off next Friday for install, by ky speed. Then it is off for the tune and Dyno by Phillip smith aka (bluecat) can't wait.
05-06-2013, 05:43 PM | #13 |
Dean Voss
HP.
What is the max HP You guys have at the rear wheel before rods and pistons?
05-06-2013, 10:49 PM | #14 | |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
I however am struggling with the drveshaft surviability. I'm at 600rwhp, should I upgrade from my stock driveshaft?? Explain please. A6 btw. |
