Old 11-30-2018, 03:01 PM   #1
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
BMR issue.
I ordered a set of 1.4" front lowering springs for my Camaro about a week ago, take the Camaro to the shop yesterday to have them installed, the shop called after an hour saying that I had been sent the wrong springs. since I supplied the springs they are charging me extra for removal and replacement to get the car back off the lift after they had disassembled everything.
I call BMR this morning to discuss what the issue is. basically they have 3-4 revisions to the same spring set (so I was told). the top of the spring that sits on the isolator will not seat correctly because I have the "wrong revision" yet this issue is somehow my fault, when on the website they list the one set for all 2010-2015 Camaros. they have sent me a shipping label and i have to send the springs i have back and wait for them to get confirmation of the shipment leaving the facility to send me the correct parts.
So now I'm out another $200 and at LEAST 4 days without my car and missing the last track day at the local drag strip. I mentioned this issue to the rep and was told that "the owner says I cannot offer you any compensation or overnight shipping because we technically did not send you the wrong parts"
UHHHHH yeah you did. and to think I was about to pull the trigger on some motor mounts and a sway bar set. Not happy.
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 11-30-2018, 03:10 PM   #2
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
I can see why you are upset. That wouldn't make me very happy either. I've had good luck with BMR, so hopefully your situation is an anomoly.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 11-30-2018, 03:50 PM   #3
rshelar
rshelar's Avatar
Drives: 2017 1SS auto vert Nightfall Gray
Glad that I spent a few more bucks and went with Eibach. They’re fabulous!
rshelar is offline   Reply With Quote
Old 11-30-2018, 04:28 PM   #4
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
A little salt to the wound
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 11-30-2018, 04:35 PM   #5
ybnormal70
Drives: 2010 Camaro SS
Looking at the BMR website, every set of springs under applications just says "2010-2015 camaro". Of course this is in the Camaro section but how the heck are you supposed to know there are different versions?
Kevin
ybnormal70 is offline   Reply With Quote
Old 11-30-2018, 04:41 PM   #6
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
That sucks
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 11-30-2018, 04:45 PM   #7
LETHAL2SS
LETHAL2SS's Avatar
Kevin
My complaint exactly. and the "Camaro specialist" and/or manager isn't there today. Which means that I cant even get any help till Monday and I most likely wont have a replacement till Tues-Thurs.
Just my luck
Hopefully once I get someone on the phone that seems to give a S*** I'll get some help here, but for now BMR has really fallen in my book and most likely wont be recommending them again, like I always have in the past.
Old 11-30-2018, 04:54 PM   #8
Terryfied
Terryfied's Avatar
Drives: 2010 2SS L99
Shoulda gone with Hotchkis
Terryfied is offline   Reply With Quote
Old 11-30-2018, 05:46 PM   #9
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Hearing this, I will be buying my trailing arms from someone else. Who knows, they might have 4 different versions and not tell me. WANKERS.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 11-30-2018, 07:44 PM   #10
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
I've never had an issue with any of my BMR parts.
StingrayblueSS is offline   Reply With Quote
Old 11-30-2018, 07:51 PM   #11
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
That's some BS, If I were you i'd be raising hell with BMR...
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 11-30-2018, 07:52 PM   #12
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Nice BMR. SCREW YOUR CUSTOMER AND BLAME THEM WHEN YOUR WEBSITE LACKS DETAIL ON THE PRODUCT S YOUR SELLING.
HOJO is offline   Reply With Quote
Old 11-30-2018, 08:24 PM   #13
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
T.C. at BMR is always good at answering questions, Hopefully your issue gets resolved! -Loyal and satisfied BMR customer
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 11-30-2018, 08:42 PM   #14
Avenging Orange
Avenging Orange's Avatar
Shit happens.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
