03-14-2017, 06:54 PM | #1 |
Drives: 2008 CL63 AMG, 2015 Z28#254 Join Date: Feb 2014
325/30/19 NT01's ?
Question for you fellow track rats. Have you run this size in back with the 305's in front or even 325 NT01s all the way around on The OEM wheels? If you have, I am curious to your experience with them handling wise. I have run a set of 305 NT01s and while relatively pleased with their performance compared to the Trofeos the 305 NT01s run a little narrower than 305 Trofeos in measurements and look kind of skinny on the rear. I am attempting to maximize the contact patch but don't want to create understeer at the limit. I remember someone posting once that they understood that GM was going to use 325 size Trofeos in the rear but liked how the car rotated more on the Nurburgring with the smaller size. Any opinions or experience is appreciated.
03-14-2017, 09:45 PM | #2 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
I too am curious because I was going to run at least 325 square knowing that the Nt01 run small.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
03-15-2017, 08:16 AM | #3 |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
There are a lot of threads covering that. Several people are running 325's all the way around and not having any issues. Its to early for me to search for them and find you links.
Here are a couple: http://www.camaro5.com/forums/showth...=trofeo&page=2 http://www.camaro5.com/forums/showth...=trofeo&page=4
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
03-15-2017, 01:12 PM | #4 |
Drives: Z/28 Join Date: Jan 2015
I actually just purchased a set of 305 front 325 rear nitto nt01 and will have them mounted and balanced next wednesday. Will provide pics once I do!
Based on some cursory research, the 325 nitto is actually just slightly wider than the 305 pirelli trofeo, and the 305 nitto is slightly narrower. I've seen a few people running 325 square with the bridgestone RE-11, however as those aren't an R compound tire, they have a slightly narrower sidewall and actually aren't even as wide as the stock 305 trofeo. I went with 305 front and 325 rear to be safe because I knew it would fit without any rubbing, however 325 square with the nt01 may also work just fine as well. |
03-15-2017, 01:27 PM | #5 |
Drives: Camaro Justice Join Date: Jun 2007
We have been running 325/30/19s all round for two years or more...
03-15-2017, 01:31 PM | #6 |
03-15-2017, 01:36 PM | #7 |
Pilot Sports on one and RE11 on the other.
03-15-2017, 03:02 PM | #8 |
199
Drives: like a granny Join Date: Apr 2013
RE-11's are heavy tires. How are they for grip ?
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon |
03-15-2017, 03:10 PM | #9 |
Thanks everyone for their replies. Cars above look great btw. Aris, how do you like the handling on track with the 305 NT01's front and 325 NT01s rear?
Also, just to be helpful to everyone a 305 or any size for that matter IS NOT consistent across manufacturers in width. The measurements on the 325 NT01s look real close to not fitting on the front. I guess I will be the guinea pig and see if it works. Also, I found out yesterday the 325 NT01s are cheaper than the 305's by about $17/tire from Discount Tire. |
03-15-2017, 05:30 PM | #10 | |
03-15-2017, 05:34 PM | #11 | |
The RE-11s are quite good and give good service on a road course. The new RE-71 is much stickier and does not live as long.
On any 5th Gen, when you stagger the tire size you will induce understeer. |
03-15-2017, 05:45 PM | #12 |
[QUOTE=JusticePete;9615380]We have been running 325/30/19s all round for two years or more...
Looks like your are using Forgeline wheels and not stock. Are the aftermarket wheels the exact same size and offsets as the factory? |
03-15-2017, 06:05 PM | #13 | |
[QUOTE=GMteSSted;9615958]
03-16-2017, 04:36 PM | #14 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
Pete
Pilot Sports? 305 in front 325 in rear?
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
