04-09-2019, 06:34 PM | #1 |
Drives: 2002 GMC DirtyMax Join Date: May 2018
Oil pump upgrade
With a 2015 1LE and doing a BTR Stage 3 cam upgrade do I need to do an oil pump upgrade?
04-09-2019, 08:52 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I've been told either a Melling high volume or a L99 pump for a LS3. I found a deal on a Melling HV.
Orange Krush II
04-10-2019, 12:25 PM | #3 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
Be cautious with getting a High Volume pump or even a high pressure pump. If the pump is a high volume pump it will empty your oil sump that much faster for no reason really. Thus if you do road courses and have any longer sweeping turns and you are going to run stickier tires I wouldn't get a high volume pump. The pump will pump your sump dry before it can return to the sump. Melling even has videos on You tube discussing when a high volume pump or a high pressure pump is really needed. Otherwise stay with a stock volume/pressure pump.
04-10-2019, 02:04 PM | #4 |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
If you are at pretty low mileage and have no issues, then you do not have to replace. I did not replace mine when going with a new cam at ~5000 miles.
2015 2SS/1LE/RECARO/NPP/RS/NAV
04-11-2019, 09:23 AM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
For a non AFM, non piston oil squirter engine, modded for more power and valve spring pressure - I would use a high pressure pump.
When the engine has some feature that needs higher oil olume - ie piston oil squirters, the high volume is a must. When the upgrades are to - power, valve spring seat/open pressure.... those upgrades in my opinion call for a little additional oil pressure. Cam and lifters with stiffer valve springs like a little extra oil pressure. Very light pressure stock type valve springs can get by just fine with stock oil pressure. The additional pressure is also better for the bearing that are seeing a higher load with a modded engine being hammered on. |
04-13-2019, 06:44 PM | #6 |
Thanks for the info. Clears up a lot of questions.
04-13-2019, 11:02 PM | #7 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Check the quality of the GM pump vs Melling and then decide. High volume will increase idle pressure and high pressure increases pressure at top of end. You will not run the pan dry @ 8 quarts. I would not recommend melling L99 version if removing DOD/VVT. I tried the GM pump, high volume GM pump, and Melling 296 pump. What worked best for me was the high volume standard pressure Melling pump (296) keeping pressure where I wanted it to be. Following installation instructions is critical for long life and going that deep into the engine for me was worth the expense.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
