03-12-2018, 07:26 PM | #1 |
Drives: 2011 1ss Join Date: Jun 2017
Lowering springs issue
I installed some used 1" lowering springs all around. I now hear a rattle/clunk every now and then coming from mainly the fromt right side strut. It almost sounds like something is loose. What are some troubleshooting tips to look into?
03-13-2018, 05:42 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
If the spring is seated correctly (there is an obvious "seat" for the bottom of the spring) then likely something is just loose - even the threads I've read where so-and-so double or even triple checked every nut and bolt, they and up finding a loose one, so all I can say is check every nut and bolt again.
03-13-2018, 06:11 AM | #3 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
Recheck all bolts and also recheck your torque spec info. Helped a friend with lowering springs and on the test dive we heard a knock as you described while under power and cornering. We went back to the shop and to recheck our work to find that we had used too low of a torque on one of the bolts. It’s easy to get confused with the various joints and knuckles having different specs.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
03-13-2018, 08:49 AM | #4 |
Only thing I haven't checked on torque specs again is the sway bar end links. Will be doing that today and then report, thanks
update : swaybar endlink was loose. all good now Last edited by who-dat; 03-14-2018 at 08:33 AM. |
03-17-2018, 09:09 PM | #5 |
Drives: 2010 2SS/RS L99 Join Date: Oct 2015
03-18-2018, 08:27 AM | #6 |
Bottom swaybar endlink was loose. Tightened a bit and the clunking/rattling sound disappeared, however I still hear a Pop when I turn hard left or go over speed bumps. Has to be the strut mount because I've checked everything else
