03-30-2020, 07:01 PM | #1 |
Drives: Red 2013 Camaro SS, Black 1980 Z28 Join Date: Jan 2015
Strut Tower Brace and Whipple 2.9 Question??
Is there a strut tower brace that works with the whipple 2.9L? I have the BMR brace on my '13 Camaro SS but now it doesn't fit with the supercharger being installed. I can use spacers to raise the brace up some but I'm concerned about the integrity of the brace if I do that. Also, does it make that big of a difference not having a brace?
I love GOD! I love my family! I love fast cars!
03-30-2020, 07:45 PM | #2 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
I have the hotchkis brace on mine (2011 SS)...fits w/ whipple, no issues. It was on my car when I bought it, but from what I hear, it's really not all that necessary...the kind of mod you buy when you've run out of other things to buy.
NY5thgen.com
03-30-2020, 08:42 PM | #3 |
Thanks....I'll check out the Hotchkis!!
03-30-2020, 08:44 PM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I have the stock 1LE brace on mine, fits without issue. I might just leave it off, after adding all that weight of the SC...
04-07-2020, 08:32 PM | #5 |
Can you post a pic of your brace so I can see how it fits over the supercharger?
04-08-2020, 10:20 AM | #6 |
Drives: 2010 SS/RS ABM Join Date: Jul 2010
This may be an option, but not sure if your Whipple will fit. This is a Halo Supercar strut tower brace. You would have to contact them to see if there is enough clearance.
04-08-2020, 10:28 AM | #7 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
I have a GM 1LE brace and it clears my Magnuson Heartbeat wih plenty of room; maybe get the GM one and sell yours?
04-08-2020, 08:23 PM | #8 |
That's the sweetest engine bay I've ever seen!! Immaculate!!
04-08-2020, 08:55 PM | #9 |
Thank you
10-1/2 years old with 40k miles and still looks like that today.
04-09-2020, 06:31 PM | #10 |
Drives: 2013 IOM 2SS/RS 2.9 Whipple Join Date: Sep 2013
I’ve got a vert and the stock brace clears the Whipple without an issue.
04-09-2020, 06:39 PM | #11 |
USA-1
Brace isn't needed.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
04-09-2020, 11:17 PM | #12 |
04-22-2020, 01:19 AM | #13 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2015
I'm running a stock 1LE brace on a 2011 with an Edelbrock E-Force on it. Has a lot of clearance under the brace.
04-30-2020, 06:15 PM | #14 | |
I.AM.
https://www.dropbox.com/s/zcekthln7q...920_n.jpg?dl=0
NY5thgen.com
