08-12-2019, 01:01 PM | #1 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Winmax help
I have the nitrous outlet winmax controller. The problem I'm having is it's reading 0.5v for idle and when I set up wot it's reading 2.0 or 2.1v. I'm sure I've read it's 4.5 for wot but mine won't read it. I set it there and tried it and the stg 1 light flashes but doesn't stay solid.
Without being in front of the controller these are the settings I can remember Stg 1....on Rpm and TPS activation Timing retard.....off. (retard via tune) Gear......0 Cyl....8 Wot..... Sensor Rpm on....4000 Rpm off.....6600 TPS on...89% (set it down from 95 to see if it would fix the issue of it not spraying) Ign type...cop I've tried programming the TPS with car running and in service mode (hold start button for 10sec) and I get the same voltage readings. TPS % displays seemingly accurate. I could set a camera next to it and watch during a pull (didn't leave enough wire to put it in easy view while driving). I am using a jms pigtail on the throttle pedal. The same one they use for their voltage boosters. I used tlhe wire that they have for you to use. It was the blk/ylw or ylw/blk (don't remember which way it is atm) Wires are soldered. I didn't use butt connectors so I don't think there's a connection issue there unless it's within the jms set up. Fwiw hp tuners shows pedal, throttle body etc at wot. (99.6 or 96.9%). I could see about setting it to read the voltage but I imagine it sees it correctly if it's showing nearly 100. Any thoughts on where my issue is?
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
09-05-2019, 11:28 AM | #2 |
Drives: 2019 Chevrolet SS Join Date: Mar 2019
I know im not answering your question, but where did you tap into for the throttle position information to the winmax controller?
09-05-2019, 11:56 AM | #3 |
I used a jms pigtail that they just started selling separate from the voltage boosters kits.
I would recommend it. Otherwise it's a very short yellow/black wire you have to tap into at the pedal https://www.camaro6.com/forums/showt...php?p=10547742 Also my issue ended up being in the relay wiring. I had the 85, 86 backwards.
"Spitfire" 427ci
09-06-2019, 09:55 AM | #4 | |
09-07-2019, 07:15 PM | #5 |
I tapped into my 2step. Lol. But I seen someone had a clamp style but idk where
"Spitfire" 427ci
