Old 08-06-2018, 07:58 AM   #1
BigAlForsyth
Drives: 2012 ZL1 AGM, LLY Duramax,93formula
RaceStar DarkStar 17" wheels/tires/sensors/lugs/rings ready to bolt on NEW!
SOLD
2012 Ashen Gray ZL1 M6 LSXperts Stage III
-LSXperts Stage 3 cam, Kooks, Corsa, ported, HX, fans, pulleys, 850cc, Rotofab
2005 CCSB Silverado Duramax 4x4, studded, heads, tuned
1993 Pontiac Firebird "Thunderchicken"
BigAlForsyth is offline   Reply With Quote
Old 08-08-2018, 09:48 AM   #2
BigAlForsyth
would consider partial trade for:
-20" drag radials to fit stock rears
-18" wheel/drag radial rears
Old 08-08-2018, 10:45 AM   #3
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
You should consider a ZL1 replica in 18x11 for a ZL1. Running the same setup I have on my buddies ZL1, fits perfect, just gotta tie back the e-brake cables.
Bump for a good looking package. I keep telling myself someday I got get serious and do a full 17" drag setup. But I'll be going 26" - NA needs all the RPM it can get!
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 08-08-2018, 12:58 PM   #4
BigAlForsyth
agreed. I would have done that to start with except i have the silver 5 spoke zl1 wheels...they are powder coated gloss black now but doesn't exactly match. i'd probably do it anyway now after going through all this.
Old 08-09-2018, 08:00 AM   #5
BandRcAMARO
Drives: 2010 Camaro 2SS/RS
What did they rub on? What size 17 inch racestars do you have? I have 17 inch rears and only had to tie back the parking brake cable.
2010 Camaro 2SS/RS
BandRcAMARO is offline   Reply With Quote
Old 08-09-2018, 08:30 AM   #6
BigAlForsyth
caliper itself. Ashamed to say i took a file and rounded the tips on the rear calipers. Made it fit but absolutely nowhere to mount balancing weights. The zl1 rotor is allegedly 1/2" bigger therefore eating up the space an SS could use for balancing weights. For the front it fit with no modification except 5mm spacer (which i now have 4) but again absolutely nowhere to mount balance weights because the whole front wheel aligns with the caliper.
17x10.5 +32 part number 92-705253DSD
17x4.5 1.75"bs part number: 92-745242DSD
