05-09-2014, 09:46 AM | #1 |
Car won't start
HELP I TURN. THE KEY OVER AND ALL THE LIGHTS ON THE DASH COME ON BUT THE CAR WONT RUN I REALLY NEED TO NO WHATS WRONG
05-09-2014, 09:47 AM | #2 |
Is it turning over? Auto or manual? Make sure it's in park if auto
Sent from my SCH-I545 using Tapatalk |
05-09-2014, 10:08 AM | #3 |
Drives: 2011 Camaro SS/RS 2SS Join Date: Oct 2013
battery or starter if no turning....yes even if power up, could still be batt
05-09-2014, 10:24 AM | #4 |
Its an auto and when I twist the key the car won't turn on at all and the car is in park a mechanic said it could be an electrical issue or the starter
05-09-2014, 11:47 AM | #5 |
Took it to Chevy they said the key lost its memory to the car
05-09-2014, 11:49 AM | #6 |
Wow... didn't know that could happen lol
05-09-2014, 12:25 PM | #7 |
yea...i dodnt think that either....huh? I didnt know there was a tx in there? What for?
05-09-2014, 12:55 PM | #8 |
Yeah they said Dont keep you key in the same pocket as your phone sometimes the two signals cancel each other out which unpairs your key to your car
05-09-2014, 12:56 PM | #9 |
Good to know. Glad it was something somewhat simple.
05-09-2014, 02:19 PM | #10 |
Since this is NOT a push button start car. Why is the FOB tied to the car? So i couldnt cut off the "key" from the FOB and use it to start car?
Im confused why a twist key car has a paired FOB. grrrrr |
05-09-2014, 03:59 PM | #11 |
Yeah me to my car only came with one key and they can't figure it out at the dealer so I Dont no what I'm going to do because my car will not start they said they tried everything and its not working
05-09-2014, 04:06 PM | #12 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Theft prevention. To quote Wikipedia:
"Transponder keys may also be called “chip keys”. Transponder keys are automotive ignition keys with signal-emitting circuits built inside. When the key is turned in the ignition cylinder, the car's computer transmits a radio signal to the transponder circuit. The circuit has no battery; it is energized by the radio signal itself. The circuit typically has a computer chip that is programmed to respond by sending a coded signal back to the car's computer. If the circuit does not respond or if the code is incorrect, the engine will not start. Many cars immobilize if the wrong key is used by intruders. Chip Keys successfully protect cars from theft in two ways: forcing the ignition cylinder won't start the car, and the keys are difficult to duplicate. This is why chip keys are popular in modern cars and help decrease car theft. Many people who have transponder keys, such as those which are part of Ford Motor Company's SecuriLock system, are not aware of the fact because the circuit is hidden inside the plastic head of the key. On the other hand, General Motors produced what are known as VATS keys (Vehicle Anti-Theft System) during the 1990s, which are often erroneously believed to be transponders but actually use a simple resistor, which is visible in the blade of the key. If the electrical resistance of the resistor is wrong, or the key is a normal key without a resistor, the circuit of the car's electrical system will not allow the engine to get started." They're also expensive to replace- so don't lose your spare! |
05-09-2014, 04:10 PM | #13 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Do a google search for GM VATS reprogram. There is a procedure that takes about 30 minutes I've seen for when you only have one key.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
05-09-2014, 04:11 PM | #14 |
I always thought the VIN would give them the info to track which frequency your car was programmed with.
