06-09-2017, 03:14 PM | #1 |
Drives: 2011 Camaro 2LT/RS Join Date: Jan 2017
Exhaust experts needed
Ok guys, like so many other v6 owners, I have decided to change the exhaust setup on my car. I have read countless posts and watched hours of YouTube videos trying to decide what route to go. Initially I wanted to have a custom 2 1/2 inch cat back made, but now I'm considering leaving the stock piping under the car and add the magnaflow resonated x and some aftermarket mufflers.
I have a couple questions 1- how much of a difference in sound can be expected between 2 1/4 vs 2 1/2 inch pipes? 2- the resonated x from magnaflow, is it 11385 (2 1/4) or 11386 (2 1/2) that people always use? Before anybody asks, I'm mainly looking for a nice sound that isn't overbearing and very little if any drone. I used to enjoy loud exhaust, but now it gets annoying to me. I know I will gain some power but this is no race car so I'm not trying to squeeze every pony I can out of it, especially since it has about 160k. Any thoughts or input? |
06-09-2017, 04:12 PM | #2 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
If your looking to not have drone issues or lower the possibity of overbearing drone, stay away from the round mufflers and look more at oval mufflers, as the drone less than round mufflers.
06-09-2017, 04:22 PM | #3 |
Thanks for the input Kenny. Right now I am considering the cherry bomb vortex (like riozland did), dynomax ultra flow, or magnaflow. I have been shopping around and saw thrush turbo mufflers. They are pretty cheap, but the price isn't that big of a deal. My biggest concern is the sound, but I haven't heard an exhaust I didn't like when using the magnaflow resonated x. Decisions decisions.....
06-09-2017, 04:24 PM | #4 |
The stock exhaust is 2 1/4 correct?
06-09-2017, 05:49 PM | #5 |
Drives: 2015 Camaro Ls Join Date: Oct 2016
You will have many differences of views on this matter.
For my V6 I went with solo performance high flow cats. Followed up with Borla Type S exhaust system. For me it sounds and works the best for the V6 . At the end of the day it comes down to cost out of your wallet. The time spent in searching for your product. The man hours putting it into the car. You will learn a lot in this exhaust journey . Trust me on that but enjoy it
MODS
K&N CAI, VMAX TBD, SOLO PERFORMANCE HFC, BORLA TYPE S CAT BACK EXHAUST. JET FLOW M.A.S OVERKILL TUNE http://www.carsponsors.com/applicati...ut/Camaro1037/ |
06-09-2017, 07:26 PM | #6 |
Drives: 2012 2LT RS White Born: 11/10/11 Join Date: Nov 2011
Magnaflow for your consideration. Minimal drone with the windows up at highway speeds. No need for a resonated xpipe IMO.
http://www.camaro5.com/forums/showthread.php?t=485712
*Grey Hockey Stripes; Heritage Grill; GM GFX - Unpainted Argent Gray; GM Dovetail Spoiler; Rivercity Creations custom painted rear bowtie, RS & Taillight Bezels; MRR M017 Graphite Wheels; Nitto NT555 G2; ACS 4Teen Heat Extractor
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A |
06-09-2017, 08:30 PM | #7 | |
06-09-2017, 08:41 PM | #8 | |
06-09-2017, 10:40 PM | #9 |
Drives: 2015 Z/22 Join Date: Aug 2015
There is a video on Youtube where the guy put a Camaro V8 Magnaflow cat-back on his V6 and it sounds pretty good. The cat-back has an x-pipe (non-resonated) and then 3" pipe to two mufflers. Not sure how the drone is.
06-09-2017, 11:29 PM | #10 |
V6 banger
Drives: 2016 Lexus CT200H Join Date: Apr 2017
After the Cat there is 2.5" then it goes into 2.25" into the stock resonator and stays 2.25 back to the tips. I have some magnaflow's (the same ones that are in Silent's video he posted in this thread) that use a 2.25" inlet/outlet I took off my car to go straight pipe. Not much louder than a stock setup but also zero drone even with the stock resonators removed. let me know if you want to see a pic of them and I can shoot you a PM.
06-09-2017, 11:36 PM | #11 | |
06-10-2017, 03:07 AM | #12 |
that guy <--------
Drives: 2012 camaro V6 LS M6 Join Date: Mar 2017
I got square mufflers on my v6 from cherry bomb the vortex mufflers. I love them alot.
Not to loud not to quite just right for me. The drone I get is little. Its hard to explain. when on the throttle I get a nice burrrrrrrr from the back but its not overbearing or defining. I can hear music on a low volume hold a conversation and get a good smile from the sound. Under heavy acceleration its really good but dissipates in the highs rpm's no nasty rasp. But if I want to sneak around the streets not draw attention to my self just normal light driving and nothing is heard at all Even at 80mph just holding at that speed nothing nice and quiet. A little gas and it can be heard as a slight reminder from the back going hay I'm here and sound good. I'm totally in love with my mufflers. |
06-10-2017, 03:33 AM | #13 |
Drives: 12SS Join Date: Apr 2010
I have a post "MESSED UP" in the LLT section. If I had to do it all over again I would have done what I winded up with the NPP exhaust or I would have saved my pennies and got a Borla system like I have on my 16 Silverado. I had the Magnaflow X pipe installed and straight piped, way to loud for me. It had a lot of drone also. Like everybody says it depends on what bothers you and what don't.
06-10-2017, 12:31 PM | #14 | |
