Old 01-16-2022, 11:21 AM   #1
cc-rider
Drives: 2010 Camaro SS
Need Help with Interchiller Install
I need help with directions and instructions for installing an Interchiller. Lots of pics below. Hoping I can get some of you who have installed these to help me get this sorted out. I purchased this kit many years ago from the Nickey shop in Chicago. As you can see, it is a RX Interchiller. But the guys at Nickey told me that it is an early build of the RX Interchiller from back when Dave (Active Interchiller) was building the kits for RX. Then I guess they had a falling out. Or something like that. So…I think this is basically an Active Interchiller for the most part. Which I know are still being sold and installed.
The kit looks pretty complete. Perhaps some of you can comment based on what you see.
Does anyone happen to have a copy of install directions for either an Active Interchiller or an RX Interchiller?
Hoping to get some responses to some of the pics with explanations on what it is, and where it’s installed & routed.
Thanks in advance for the help!
cc-rider is offline   Reply With Quote
Old 01-16-2022, 11:22 AM   #2
cc-rider
Any help with routing here on the brick here?
Old 01-16-2022, 11:23 AM   #3
cc-rider
Any help with how this diverted gets routed?
Old 01-16-2022, 11:25 AM   #4
cc-rider
Any help with these?
Old 01-16-2022, 11:27 AM   #5
cc-rider
Wiring…looking for some help here as well:
Old 01-16-2022, 11:30 AM   #6
cc-rider
Here’s the rest of the photos of all the parts. Again…any help on what they are, where they go, and how to route them would be much appreciated.
Old 01-16-2022, 12:41 PM   #7
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Looks like you have the competition kit, which allows you to use the interchiller function while in the staging lanes. Separate comments to follow.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 01-16-2022, 12:57 PM   #8
Batmanntexas
Top picture is the competition solenoid and associated control relay and toggle switch. This item should be installed between the compressor and cabin evaporator, so that when activated, it shuts off the refrigerant flow to the cabin evaporator. This keeps the car from dropping condensation on the track.
Bottom picture is the vacuum valve to control the water diverter valve (Black plastic 4-port object). This valve is electrically operated, tapped into the a/c compressor activation (+) wire. The function of this valve is to isolate the intercooler/heat exchanger a the front of the car. When activated (A/C on), the fluid path is: Reservoir --> pump --> interchiiler --> blower --> Reservoir
When A/C is off, fluid path is: Reservoir --> pump --> heat exchanger --> blower --> reservoir.
COTW 9/8/14
Old 01-16-2022, 01:01 PM   #9
Batmanntexas
The LED is wired to the competition solenoid/toggle switch assembly so that you have a visual indicator when it is activated. While nice to have, not required for operation.
I can't help on the A/C lines, as mine were hard lines and I opted for the non-competition model.
COTW 9/8/14
Old 01-16-2022, 01:02 PM   #10
Batmanntexas
Interchiller hose routing diagram
Maybe this will help as well.
COTW 9/8/14
Old 01-16-2022, 01:33 PM   #11
cc-rider
Got it. That’s super helpful. Thank you. I think I got the idea of how this thing works. I don’t plan to go to the track. Just a street car. So I think I’ll skip the cabin shut off set up.
Has anyone ran into trouble burning out the ac system by running one of these? Or cabin ac not working well in hot weather because the system can’t keep up with both the chiller and cabin ac?
Since I’m not running at the track…Wondering if maybe I should plumb the competition mode valve to be able to shut off the chiller when I want. That way I can have cabin ac without the chiller running. I guess the only reason to ever do that would be if the answer to my question above is “yes” there has been incidents where the overall system can’t keep up…
Old 01-16-2022, 02:08 PM   #12
cc-rider
One more question…I’m curious as to why the flow doesn’t go from the chiller into the heat exchanger? Now I understand that in hot weather the Hx would actually be heating the water a little bit after it leaves the chiller. But I wonder if it could also serve as a bigger reservoir of cold water that would help keep the system cooler longer during longer pulls (because the ac shuts off under hard acceleration).
Perhaps just adding a bigger reservoir hidden somewhere after the chiller would work to serve the same purpose and not actually heat the post chiller cooled water like a heat exchanger might in hot weather.
Old 01-16-2022, 05:30 PM   #13
cc-rider
Anyone have a diagram or a pic of how the ac/freon lines run? Where they tap into the ac system?
Old 01-16-2022, 06:14 PM   #14
SoChrisB
SoChrisB's Avatar
Drives: 2012 Camaro 2SS/RS
I'd give Dave a call. He sent me a huge Google drive with a ton of useful info.
SoChrisB is offline   Reply With Quote
