10-21-2015, 05:43 AM | #1 |
Right Cam
Drives: 2010 LS3 / 79 Z28 Join Date: Jun 2009
Any mud flaps for 2014-15 Camaro?
Does anyone make an effective splash guard for the 2014 body? The 2010 style won't fit, and I want something that will offer protection from sand, gravel, etc.
Any recommendations?
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
10-21-2015, 11:03 AM | #2 | |
Drives: Replacement 2SS 'Vert 67 Cutlass Join Date: Aug 2015
http://www.rpidesigns.com/shop/item.aspx?itemid=1922 I haven't ordered them yet, but they seem like the best option so far to me. Tim |
10-21-2015, 04:46 PM | #3 |
Right Cam
They look like they'll do the job, and the price isn't too bad, thanks!
10-22-2015, 11:23 AM | #4 |
I run 2 catch cans...
^ Those fall apart in less than 3 months. Cheap and brittle plastic.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
10-22-2015, 11:35 AM | #5 |
Right Cam
Hmmm, any other choices?
10-22-2015, 02:01 PM | #6 |
Drives: Black 2015 2LS, Teal 1991 RS Join Date: Oct 2015
Manufacturer part number 23114083 is what I was given by the parts department at my dealer for mud flaps. I have yet to order them because they are a bit pricey but if they work and last, I think they're worth it.
10-22-2015, 03:59 PM | #7 |
Drives: 2014 Camaro 2SS Join Date: Oct 2014
I've had the RPI $50 set for almost a year and no issue. Definitely not brittle or falling apart...
10-22-2015, 10:46 PM | #8 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
+1. Mine lasted 2 winters before needing to be replaced.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
10-23-2015, 11:59 AM | #9 |
10-23-2015, 04:42 PM | #10 |
Tip: Don't bother using the "L" brackets for the rear flaps. They eventually come loose and are a bigger pain than not using them.
10-23-2015, 04:44 PM | #11 |
War Horse Pilot
I have the RPI stealth guards on mine too. Over a year and no issues.
10-24-2015, 05:43 PM | #12 |
Right Cam
Any idea what they look like? Are they flat plastic or molded?
10-24-2015, 06:43 PM | #13 |
They are molded. Here is the link to the GM site for their accessories for the 14-15 body style: http://www.chevrolet.com/camaro-sports-car/accessories.html The mud flaps are listed as splash guards and the only picture they have is of the rear wheel but they are supposed to be the same look on the front. I will most likely be ordering a set of them to put on mine myself. My dealer quoted me $100 install and I'm more than capable of saving that $100 |
10-24-2015, 11:08 PM | #14 | |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I've had these for almost two years. Pretty happy with them. Don't think these particular rears will fit your car though. But the kit tmaleck posted should work fine.
