Emblempros
Old 04-09-2018, 07:46 PM   #1
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Hooking up with nitrous and a 3200 stall
I have added a Zex nitrous system on my Camaro for drag racing. It really gives the car a good kick in it's heavy @ss.
My car doesn't have a lot of power without the nitrous. Around 360rwhp, I'm currently using 125 jets with nitrous.
The problem is........ it's not hooking up most of the time now.
I have 18" Z06 replica's and MT ET Street R 305/45/18. This is a tall tire @ 29".
I realize if I do hook up now, the stock spider gears aren't going to handle 1.5X 60' for long until they break. I added a line lock recently as well, but still get the 1 wheel burnout most of the time from the posi.
I plan to put an eaton tru-trac in to fix that, and while the pumpkin is out, I also plan to change the gears and diff bushings.
But, I already can't hook.
With the 125 shot....... gears would just make hooking up even worse, wouldn't they? If the 327's wont hook, no way 391's or 410's will.
I normally flash the converter when launching, it gets the best 60' that way.
Any of you guys running a stalled converter with nitrous? What size DR's are you using to hook?
Here's 2 passes. One hooking, one spinning through 1st and into 2nd. Both passes made yesterday. I normally abort the pass when spinning so much, but on this pass I was running alone, so I finished it out just to see how bad it would be. It's awful.....
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, Tuned via SCTX4 by Dynosteve at RDP.
Joe M 2012 2SS is offline   Reply With Quote
Old 04-09-2018, 07:49 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
psi...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 129K! - All work by me...
Old 04-09-2018, 08:07 PM   #3
Joe M 2012 2SS
Drives: 2012 2SS
Originally Posted by frankwjr View Post
psi...
I started with nitrous on 20 psi in the MT's, almost got sideways out of the hole , went down to 18 still spinning. I currently run them at 16. You think I need to go even lower?
Or are you talking bottle pressure? 950-1050 is where I'm usually at.
Old 04-09-2018, 08:29 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Progressive controller?
2013 1le- LT's w/o cats, Borla Atak, Z28 cai, TSP stage 4 cam, SLP 25% udp, LOD intake, cnc heads by Wegner Automotive, Bo White ported tb, H&R drop springs. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle. (There may be some junk in the trunk from Induction Solutions
Clarkstar is offline   Reply With Quote
Old 04-09-2018, 09:45 PM   #5
Joe M 2012 2SS
Drives: 2012 2SS
I don't think this would work with the nitrous system I have. The Zex system I have uses their active fuel control system.
It basically varies amount of nitrous/fuel based upon bottle pressure and fuel pressure, so you can't run too rich or too lean.
Sudden changes in nitrous/fuel delivery could cause this feature problems. I want this working properly every time I use it.
Old 04-09-2018, 09:53 PM   #6
frankwjr
frankwjr's Avatar
currently at 13 on the NT05R's...but if your posi is actin up then even psi won't help...this would...https://www.camarocentral.com/2010_2..._p/clu-595.htm
l8tr
Old 04-10-2018, 12:24 PM   #7
WoodBoss
"Old School"
WoodBoss's Avatar
Drives: 2010 2SS L99
Joe, That differential will need to be beefed up for sure, if only one tire heats up at the burnout obviously one tire will have more traction than the other. Try to make a few runs stalling up to as high as you can with the brakes on, that may help. We basically have the same setup except for the converter and tires. Faster times are in there just need to launch differently.
Back In The Saddle - Earley 2010 2SS IBM A6 #10244 Built - Roto-Fab CAI, Muffler/CAT Delete, 17" Mickey Thompson ET DRs, RDP Tune, ZL1 Fuel Pump, BW Stage II Ported TB, Speed Engineering 1-7/8" Longtubes, ZEX Nitrous 150HP Shot, Lingenfelter 160* Stat, NGK TR6IX Spark Plugs & Elite Catch Can, TCI Line Lock, JRE Trans Dipstick, BMR Trailing Arms & Toe Rods, 11.6 sec @ 120 mph - 1.59 sec 60' - 1/4 mile pass Check Out My Youtube Channel For 5th Gen Camaro Drag Racing & How To Mods https://www.youtube.com/channel/UCyG...GR9gDm6PO-27rg
WoodBoss is offline   Reply With Quote
Old 04-10-2018, 05:16 PM   #8
Joe M 2012 2SS
Drives: 2012 2SS
Yes I'm going to have to make changes in the diff for sure. Our cars do have almost the same mods. What's really surprising to me is without a stalled converter in yours, our cars run very close to the same ET. Your actually a tenth or so faster now since you switched to the race star 17's.
My car ran a best of 8.20 before the converter, and with it a 7.84. The nitrous dropped me about 4 tenths, but your car on the stock converter dropped 7 tenths with the same shot.
I tried brake stalling it with the converter in before nitrous, but the car ran slower vs. flashing it. I haven't tried brake stalling since adding nitrous. I also have considered moving the activation switch from being hidden to a spot I can reach while making a pass, to turn it on after the 60' mark and see how that works out.
I'm not going to get a chance to try anything else now until I make some changes in the differential.
The differential is definitely the weakest link on our cars for sure once you add power. The clutch pack kits are said to work up to around 600 hp. But the factory spider gears can't handle a 1.5X 60' time for too long. Ask Pro Stock John, he broke his when he began getting 1.5X 60'.
I'm going with the tru-trac instead of the clutch pack kits. I like to drag race, and it's much stronger than a clutch pack.
The tru-trac is supposed to be good to 1000 rwhp, and I'd rather spend a little more now than have to re-do it again later.
Here's a good article on the Eaton Tru-Trac for the 5th gen Camaro.
http://www.lsxmag.com/tech-stories/d...gen-camaro-ss/
The dilemma I have though is what gear to put in with it. I know everyone loves the 391's on N/A cars, but it might be too much for nitrous with a stalled converter. I was kind of hoping someone who ran nitrous with a stalled converter weighed in on what gear they run, but no one has yet.
Old 04-11-2018, 08:12 AM   #9
WoodBoss
"Old School"
WoodBoss's Avatar
I would consult with Janetty, PCM of NC & DynoSteve on what path to take to get the best results regarding Nitrous/Stall/Gears. Good Luck, let me know what the plan is.
Old 04-11-2018, 03:30 PM   #10
Joe M 2012 2SS
Drives: 2012 2SS
Steve is on it. From what I understand so far, the RPM when crossing the 1/8th mile mark, the tire height, and the MPH are needed to figure the proper gear for my current set up.
It will be some time before I run at the strip again. The trutrac and gears need a 500 mile break in, and I drive about 4 miles each day. So probably fall of this year before I can run again.
Steve will get it right, of that I am sure. I'll just need to record a pass after the initial tune, send it to him, and he will make any necessary changes.
I don't know much at all about tuning but I do know this. A good tuner like Steve will get your car within 95-98% of best possible results with a handheld vs. what he would get on a dyno.
The dyno is basically a stationary street, where a tuner can see what is going on. With the SCTX4, the tuner needs data because that is the only way they can see what is going on after adjustments are made. It just takes some patience and realization that without data, he can't improve what the car is doing.
When this pollen subsides, I need to bring the Rupes up to your house and get that metal flake popping in your paint!
Old 04-11-2018, 11:54 PM   #11
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Yeah I broke the spider gears when I started running 1.50 ish 60 foot times. Swapped out to the TT, still had my slicks on, and went 1.47 and it lives.
Any video of your car launching Joe? Does it weight transfer?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-12-2018, 08:51 PM   #12
Joe M 2012 2SS
Drives: 2012 2SS
I don't have a video camera, Franks girlfriend Joanne got these two passes on video. The first one had a little spin. 1.70 60' 7.55 @ 94mph. The second pass I just abandoned after the launch due to so much spin. 2.0 60'.
If you don't want to watch the whole video, the passes were at 5:00 and 15:30 of the video.
I've had several 1.5X 60' passes at Shadyside here in Shelby, she squats down nice when she hooks!
I have done a lot of research on the forums, and I see it is a common thing for the clutch packs to go out, making the differential open ended. I still can occasionally get the drivers side wheel to spin when burning out, and this is when I get the good 60'.
I read one thread where they did the posi-mod, and later broke the spider gears doing a 1.5X 60'. Based upon your experience with it as well, that is why the trutrac is going in. No clutches to wear out, no spider gears to break.
It's going to cost me a good bit of $$ to get done, as I'm also adding a 3.91 gear per Dynosteve's recommendation. But I'd rather spend it now than save some by just doing the posi-mod, and then have to later on replace the factory diff anyway from the spider gears breaking.
Here's a really good video explaining the differences in differentials for anyone interested.
Old 04-24-2018, 04:36 PM   #13
Joe M 2012 2SS
Drives: 2012 2SS
Well everything arrived today. Eaton Truetrac, Motive 3.91 gears, and Ratech install kit.
Installation will be early next week. I found a local shop, only 10 miles from my home, the guy has 35 years experience doing this type of work. $650 for installation. Seems reasonable for an 8-10 hour job.
Old 04-25-2018, 10:34 AM   #14
WoodBoss
"Old School"
WoodBoss's Avatar
Nice, hope to see you out making some runs soon. Those gears are going to be pretty stout.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
