Rick@Livernois
Old 05-21-2018, 08:18 AM   #1
Huron Speed
Drives: 2012 45th SS
Those with Adjustable Shocks, come in to discuss your settings
Recently switched from Stock suspension over to a BMR Rear Drag Pack w/ Strange Double Adjustable Coil-Overs front and rear.
At the track yesterday working on dialing it in, and curious where you are are having some good luck.
Currently have the front set at full loose on the extension and full tight on the compressor. Brings the front end up nice and stays. Maybe a bit too quick however.
Rears we bounced around all over the place and winded up back at the middle of 5 and 5 clicks on both rebound and compression. Track wasn't as great and also on a 17" wheel still so it was a tricky day.
Post up what you are having good luck with!
Hoosier 28x10x17 Slicks around 14psi
Jon
Huron Speed is offline   Reply With Quote
Old 05-25-2018, 07:00 PM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I have rears, I am still experimenting.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-25-2018, 07:56 PM   #3
QUICRNU
QUICRNU's Avatar
Drives: 2010 ABM SS/RS A6
Sorry I do not have the same, Im on Supercars.
3 off max in the front same direction you are.
I ended up at 5 from soft compression of 32 possible and rebound was 3 from Hard of same 32.
Not sure this helps bit I cut a 1.402 on 17s with M&Hs at around 630ish rwhp with LSA blower
Saw low 1.4x alot.
Car weighed 3800 no driver.
2010 ABM A6 w/Mojave seats!
584 RWHP / 520 RWTQ
Build Thread - http://www.camaro5.com/forums/showthread.php?t=481043
QUICRNU is offline   Reply With Quote
Old 06-14-2018, 04:23 AM   #4
Squintah
Squintah's Avatar
Drives: Camaro 45th A. E. Dragster
I got a KW V3 with double adjustable front and rear shocks.
In the front I've set its rebound to full soft (16 klicks) and compression to full stiff (12 clicks).
In the rear I've set its rebound to full stiff (16 klicks) and compression to full hard (12 clicks) but I think, because the springs are the same it's not good and changed the compression back to the middle (6 clicks).
Any ideas for an improvement??
I got 325/45R18 Hoosier Drag Radial II on the rear and stock wheels on the front ...
Car weight is 3750 lbs including driver ...
Squintah is offline   Reply With Quote
