Old 07-08-2019, 05:30 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Water meth
Ok so I'm fighting bad intake temp issues.
Twin turbo built LQ9 ls3 heads Holley sniper intake custom air to air intercooler. 25lb of boost full E85
Currently running snow performance meth kit with dual #6 nozzles. Biggest they offer.
Correctly running 100% methanol.
At the track on trans brake I'm seeing 95* iats at the end of the pass I'm seeing 197*.
Snow says its because im not running their boost juice. Seems more like they want me to buy more stuff from them.
Am I actually better off dropping to a 50/50 mix or keep on the 100% methanol?
I want to avoid air to water because I street drive this car alot.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 07-08-2019, 06:29 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Water cools better, I run boost juice...
-Don
747 RWHP 794 RWTQ
Old 07-09-2019, 09:13 AM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
A/W is better in every way, even street driving. Just run water in the tank and you're golden for street driving.
Sounds like you need a more efficient A/A intercooler though. I'm seeing like 120 at the end of the 1/8
ttshovel is offline   Reply With Quote
Old 07-09-2019, 10:02 AM   #4
hillshooter
Drives: 2015 Camaro SS commemorative
what happened to your other thread? You are going down the wrong path, mathanol isnt goign to fix this , you obviously arent running enough intercooler. Lets see what you currently have.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 07-09-2019, 02:13 PM   #5
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
I told you in your last thread , when heat turns water into steam the molecules expand over a 1000 times. That reaction reduces heat tremendously. Meth is only to add fuel and reduce predetonation...
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 07-09-2019, 02:38 PM   #6
davidscamaro
Meth no make heat go bye bye,
Water make heat go bye bye
Just a little joke ^
Just trying to say meth is only a fuel , it would be the same logic that increasing your fuel injectors output will cool down your boost , and we all know that does not work
Old 07-09-2019, 03:46 PM   #7
ttshovel
ttshovel's Avatar
Okay so methanol shines during combustion. Yes your iats may be high but the methanol is doing its job. Plus you're not using enough methanol to drop iat significantly.
If I was in your shoes, I'd run 15lbs worth of nozzle at a minimum and pull some fuel from your table
Also is your iat sensor after the nozzle to actually show the drop? But I'd for sure stick with 100% methanol
Old 07-09-2019, 04:36 PM   #8
AGP Turbo
Drives: All things Turbocharged
Water is good at cooling things and putting fire out, so while it will lower IAT's, massively reduce knock, allow more compression, boost and timing on lower octane fuels. It does all of this at the cost of horsepower because it's neutering the combustion process. That is useful for getting an unstreetable race engine to be usable on the street with pump gas, when you don't need to make maximum power and don't want to use race gas all the time.
Whereas methanol both cools very well, and is a race fuel that is highly flammable. So it it will lower IAT's, massively reduce knock, allow more compression, boost and timing on lower octane fuels. It's does this all while helping you increase power. Even on E85 cars that don't have a hint of knock, we still gain power from the cooling effects.
Better turbos, better intercooling, better engineering, better design/ application of everything should all be done before just dumping loads of meth into an engine to bandaid these shortcomings. Meth sprayed before the throttle body into an LS3 shape intake manifold mostly goes into Cyl 7&8 and very little into #1&2.
AGP Turbo is offline   Reply With Quote
Old 07-09-2019, 04:41 PM   #9
hillshooter
tested and proved.
Old 07-09-2019, 04:49 PM   #10
AGP Turbo
Originally Posted by hillshooter View Post
tested and proved.
Yep, didn't that screw you pretty bad?
I've seen that soooo bad that turning the meth completely off gains a bunch of power. The car is basically running really well off the front 6cyl. and the rear two and dragging you way down.
Old 07-09-2019, 07:05 PM   #11
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
We spray about 2 feet before the throttle body. But I have no idea about the dispersing into each cylinder.we also spray from the middle of the tube and not the side.
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 07-10-2019, 04:17 PM   #12
hillshooter
I am going to guess that OP doesnt have an intercooler at all.
Old 07-11-2019, 07:33 AM   #13
2010_camaro
OP has an intercooler......
Old 07-11-2019, 07:55 AM   #14
2010_camaro
I pulled the intercooler and ran a test pipe. Intake temps dropped significantly in a pull. I'm either out flowing the intercooler or something inside it is clogged up. I cant remember the CFM the core was rated for.
