05-23-2012, 08:31 AM | #1 |
Latest Heat Exchanger Pics - Black Thermal Coating
Just wanted to share some more pics of our heat exchanger for the Camaro's and this time with our optional Black Thermal Barrier Coating.
We have HUNDREDS of these IN STOCK and READY TO SHIP TODAY Some nice details about our unit. This double pass heat exchanger is of the highest quality. The cores, welds and design are used in many high performance applications for both street and track use. Furnace brazed core (no epoxies) with beautifully tig welded tank construction High efficient double pass design vs. others single pass. Using years of experience, advanced design, and thorough testing, Torq Heat Exchangers are designed to promote optimal air flow and cooling by utilizing appropriate fin count, tube size, core thickness, and fin serration for each particular application. Optional Dual 10" fans provide the ultimate in airflow at all vehicle speeds |
05-23-2012, 08:59 AM | #2 |
Cooter
Drives: my wife crazy Join Date: Oct 2011
That looks nice in the black thermal coating.
#1451 - 2012 ZL1 - White, Black Wheels, Manual, Suede Package, and Exposed Hood Insert. Delivered on 6/20/12. Thanks to Jason from Symdon Motors in Evansville, WI.
05-23-2012, 10:06 AM | #3 |
Banned
Drives: SHELBY GT 500 Join Date: Apr 2012
Go with the dual fan type. Works great!
05-23-2012, 10:57 AM | #4 |
Aerospace Machinist
Drives: 2012 Victory Red ZL1 w/ ECF Join Date: Nov 2011
Maybe I do not fully understand the theory behind how heat exchangers work but I was under the impression that they radiated heat from the hot water to the cooler air that flows through the heat exchanger.
It seems to me that a thermal barrier would create a thermal barrier that would reduce the heat exchanger's ability to transfer heat from the water to the air. You should actually be using a heat dissipating coating or nothing at all. Bare aluminum dissipates heat very well. The kit does look really nice, but I would stay away from the thermal barrier. |
05-23-2012, 12:45 PM | #5 |
Drives: Camaro ZL1 Join Date: May 2012
Correct me if im wrong, but would you want heat dissipation coating on the heat exchanger? A thermal barrier is the opposite of what you are trying to accomplish - Check out Cerakote "Transfer Black C-187" or "Arctic Black P-202" from NIC Industries.
05-23-2012, 12:59 PM | #6 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Does the front bumper have to come off to install this?
05-23-2012, 01:35 PM | #7 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I didn't see anything on their web site regarding a black thermal coating, but here are the specs for the heat exchanger (radiator) from their site.
Product Specs Radiator StyleCrossflowOverall Width (in)26.25" Overall Height (in)11.375 Overall Thickness (in)2.0" Row QuantityDual PassRadiator FinishNatural Radiator MaterialAluminum Core Height (in)11.0 in. Core Thickness (in)2.0 in. Core Width (in)26.00 in. Fan IncludedNo QuantitySold individually Notes298sq.in Front Face Area! |
05-23-2012, 03:42 PM | #8 |
SLOBRA1
Drives: GT500/Cruze/DMax/Cobra Join Date: Feb 2012
2010 GT500 Best ET=10.10 - Best Trap=143.59mph
2003 Turbo Cobra Best ET=8.27 - Best Trap=166.42mph |
