Old 02-13-2018, 04:14 AM   #1
camaronurse
Drives: 2005 rsx, 2012 camaro 2lt t3 ed
5 years later Smog fail.
Hey guys I need your help. I'm from CA. I have a 2012 Camaro with 15,000 miles, it has a CAI cold air intake. I'm due for a smog. It failed on my first test telling me that I need the EO# for the intake or I can just put the old intake back and try again. Anyone here having problems with smog using CAI cold air intake? Any advise?
Thank you!
camaronurse is offline   Reply With Quote
Old 02-13-2018, 05:28 AM   #2
motorhead
Did it actually not pass, or did they just fail you because of the CAI?
Old 02-13-2018, 10:06 AM   #3
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
I had to reinstall my stock airbox to pass. It didn't even make it to the rollers before the guy said I needed a sticker or the oem box.
HyperV117 is offline   Reply With Quote
Old 02-13-2018, 10:07 AM   #4
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I would just install the stock intake, its really not that long of a process to do.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 02-13-2018, 10:23 AM   #5
1543R2
1543R2's Avatar
Drives: 2011 2LT RS Blk/Blk
Last September I had to have my Camaro smogged for the first time. I had to remove my oil catch can and put the stock intake back on before it would pass the visual inspection. It passed with no issues. Only have to do it every other year, no big deal... Good Luck!!!
1543R2 is offline   Reply With Quote
Old 02-13-2018, 11:55 AM   #6
camaronurse
Thanks for the advise guys, i will just install the old intake. I also have MRT 2.0 exhaust. Will it also affect the smog result?
Old 02-13-2018, 01:11 PM   #7
SSEssence
Instagram: Sangstah
SSEssence's Avatar
The exhaust will not matter as long as you have the stock cats intact
Old 05-14-2018, 12:22 PM   #8
Kessler
Kessler's Avatar
Drives: 2012 IOM 2LT RS A6 w/ BA
Same for me. First year I had to smog. Failed VISUAL, they refused to test because no CARB number for the CAI. (CAI's website says they were too cheap, or to lazy to request a CARB number). And then they did not like the 'vented oil cap' I said Valve cover was vented before I put on the cleanside catch. So, Every 2 years, back to stock for the test. Can't wait to escape California.
ToDones -
Apex Scoop & Washer Relocate - CAI cai - Elite CC - Elite Clean Side Separator -
MRT v1 Axle Back customized w/ J-Pipes - Black Out Headlight/Tail Light -
Black Out BowTies - Black Out 'camaro' - Black Out Brake Light Chrome Bezel -
JL Audio XD400/4 - Sub Thump Sub Box 2 DVC 10"s - HIFONICS ZEUS 1000.1
Escort Redline - VIOFO Dash Cam - Continental Extreme Contact Tires
Gary's Customs ZL1 Front Bumper, ZL1 Rockers, & ZL1 Spoiler - Paint matched IOM
OverKill 80mm T-body - JacFab Ported Intake Manifold - JacFab Extendolator 3/4" Spacer
ToDos -
Tune?
Kessler is offline   Reply With Quote
Old 05-16-2018, 03:04 AM   #9
Dave@Sturgiscamarorally
Dave@Sturgiscamarorally's Avatar
Drives: 2010 ABM 1SS
One of the few things I don't miss. State inspections...
2010 Aqua Blue 1SS
KWC 3pc forged, Seibon hood, ZL front end, MGW, ARH full exhaust w/ Doug Thorley axle back, BTR4, Roto-fab, LSXR 102, NW 102, 3.91s
Dave@Sturgiscamarorally is offline   Reply With Quote
Old 11-08-2018, 12:02 PM   #10
pinoyplaya
Drives: '13 SS RS
Will tuning impact results? Doesn’t it as long as the car shows correct sensors and etc, it should pass regardless?
I have my muffler deleted. Hopefully that passes visual.
I wanna do CAI but need carb approved ones. Any recommendation?
2013 Camaro SS RS
pinoyplaya is offline   Reply With Quote
Old 11-08-2018, 05:21 PM   #11
silverstorm
silverstorm's Avatar
Drives: 2014 Camaro 2LS
Cali has it rough, here in TN all they do is check the pressure of the gas cap and check the OBD
silverstorm is offline   Reply With Quote
Old 11-08-2018, 07:42 PM   #12
pinoyplaya
Drives: '13 SS RS
If you failed smog don’t they put you in this black list?
2013 Camaro SS RS
Old 11-08-2018, 11:55 PM   #13
rocknroll_jeph
rocknroll_jeph's Avatar
Drives: 11 Camaro V6 RS, 03 BMW Z4
I'm surprised to hear that. I have a 2011 with a catch can, ported throttle body and aftermarket exhaust and it passed with flying colors. The lady even remarked how low my numbers were after seeing the printout. I run with a K&N intake and hyper tech tune, but I took those off for the test. However, I am not in California, I don't know how different the tests are. Mine is tested yearly as well, this year they didn't raise the hood so I'm going to try leaving the K&N on for next years inspection to see the difference.
rocknroll_jeph is offline   Reply With Quote
Old 11-09-2018, 08:54 AM   #14
pinoyplaya
Drives: '13 SS RS
Numbers isn’t what fails it but rather visual. Just need to find a different smog place to test.
2013 Camaro SS RS
