05-14-2015, 11:16 PM | #1 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Turbo sizing?
Still planning to put my LFX engine sitting here to some good use, as well as the LF3 parts that I have collected.
Not wanting to splurge on the LF3 turbos, after quite a bit of research I discovered that two of the four holes on a T4 flange turbo will line up with the exhaust bolts on the LFX head. I think with a simple adapter plate a t4 flanged turbo could potentially bolt right to the head. The problem I am finding with a lot of turbos that have a T4 flange is that they seem very large. Most likely too large for the 3.6. Turbo experts, what do you think about the sizing specs on the following eBay special? http://m.ebay.com/itm?itemId=380378837493 I may or may not go with the eBay special, but I have been searching for something that I think may work well for twins with a t4 flange Any insight would be much appreciated. |
05-15-2015, 02:58 AM | #2 | |
Endlessly Wrenching
Drives: VE SV6 S2 manual Join Date: Nov 2013
05-15-2015, 06:37 AM | #3 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
Yeah I would think that's a little big for twins. I'm running GT28s on mine and they definitely seem like a good matchup.
05-15-2015, 06:59 AM | #4 |
Still planning on putting this in a rat rod? My car is so much fun even as heavy as it is.. if this setup was in something 1,000lbs lighter it would be crazy!
05-15-2015, 01:58 PM | #5 | |
Thanks for the insight guys. I'm still kinda stuck on the T4 flange thing at the moment, but we'll see what happens.
I'm just taking a wild guess here, but I'm thinking it's probably going to weigh less than 2000lbs. Maybe 1700-1800lbs? Perhaps a slightly oversized turbo with a little more lag will help keep the tires from blowing off? In something that light, lag may not be quite so noticeable. The cab I'll be using is a 46 Chevy truck cab. The frame I'm making myself out of aluminum. It's basically a replica of a 32 ford frame, 3/16" aluminum, fully boxed. |
05-15-2015, 06:33 PM | #6 | |
05-15-2015, 10:25 PM | #7 | |
Also, I ran twin 57mm t3/t4 turbo's with stage 5 turbine wheels with t3 .63ar huosing (roughly same size as gt35 wheel) at front and rear mount and spooled well in both positions (near instant spool at front). Just use the .68ar turbine housings and you should have fun! You could even run two 60mm 60-1's with p-trim exhaust for even more power with slightly more lag. Also, the trim for the 60-1 wheels are made for high efficiency at lower boost levels. In the link below, the Infiniti G35 twin kit uses twin 60-1's and that motor doesn't flow as much as ours. Looking at the dyno it probably hits full boost by 3.5-4.5k, will spool faster on the LFX: http://www.turbokits.com/Infiniti/G3...Turbo_Kit/314/
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
05-17-2015, 09:59 PM | #8 | |
Thank you for the post and the excellent info. I was thinking the ebay special would probably work ok for twins, but most likely too small for a single (choke out the top end). Seeing as I'm going to try to end up using the LF3 intake, twins only make sense, plus it will look cool with one hanging off each side. |
05-18-2015, 06:48 AM | #9 | |
You should post up a link to your thread over there so we can see. LFX is Camaro related! |
05-18-2015, 05:07 PM | #10 |
Drives: 2015 LFX Auto Join Date: Apr 2015
Would never trust one of the ebay turbos for long.....when the bearings go and the turbine blades start eating the housing and shedding metal that's your engine your going to have to replace in the end. Have yet to see one go more than a few thousand limes w/out failing...just look at the STS cheap ones as an example.
05-19-2015, 11:02 AM | #11 | |
05-19-2015, 11:08 AM | #12 |
And dammit Jason, you got me thinking about rat rods again so I wheeled my motor out of the back and unwrapped it. It still looks good. Now I've been looking at old trucks and cabs on craigslist lol. Thanks a lot!
05-20-2015, 02:04 PM | #13 | ||
Perhaps this turbo might be a little better quality?
www.ebay.com/itm/331316466454 Also water cooled, may be better for the longevity? Quote:
If you're serious about building something just keep your eyes open for the right deal... I had been looking for almost 2 years before picking up this cab I'm going to be working with. A lot of things that popped up were either too far gone for me to wan to screw with, or too much money. Not exactly what I wanted, but it was in great shape and the price was right... Plus I think most of the Chevy truck cabs are pretty similar from 37-46. My cousin is building a 38 right now, and most of our pieces seem interchangeable from what has has had to borrow from me for patterns etc. Couple frame rail construction shots: Pardon my messy garage. As of right now, I'm not planning on chopping the top. I'll get together at least as a roller and see how I fit in it first. Last edited by Jason@JacFab; 05-20-2015 at 05:00 PM. |
05-21-2015, 02:56 PM | #14 |
Nice find! I've had my eye out for something but like you said people usually want a fortune for them. I can find 47 and newer Chevrolets pretty easy but I really want something older. I would even do an older 30s 40s ford or dodge pickup cab. That will be the first thing I buy, the cab or truck. I know a couple hot rod shops that will build me a custom chassis to fit my motor/trans and cab. I wish I had your fab skills and could do that myself! I could possibly use an S10 frame and do it myself but definitely wouldn't look as cool going that route.
Those frame rails are sick! |
